Question about Frigidaire FGF316 Gas Kitchen Range
Oven will not ignite while glow ignitor is on...
Glow ignitor working, but the oven won't ignite... I hae only 2.3 volts to the safety gas valve... So does this mean that I have a bad valve, or not enough voltage present to allow gas flow? Should it 3 volts or 3.5 volts at the vlv? I am working on a Frigidare Gas Oven model# FGF316BSB Ser# VF35124945 Thank you kindly in advance
  • 370 Answers
The ignitor has to draw enough current to open the gas valve. The cheapest way is to just replace the ignitor and that will fix it 9 out of 10 times.
Posted on Nov 18, 2008
Oven lights but doesnt stay lit. Does anyone know what the problem could be and how to remedy it?
Safety valve failure. (TURN OFF GAS, then do as follows): Check voltage when the stove is "on" at the safety valve. If it reads 24 volts, then the safety valve is bad. If it reads _less_ than 24 volts, then the ignitor is bad (EVEN IF it is glowing red). The problem is that the ignitors can glow red, but still "eat" so much voltage that the safety valve fails to open (or stay open). It is a "resistance" problem inside the ignitor, even through it appears to be good. // Simply stated: 24 volts at the safety valve means bad safety valve. Less than 24 volts at the safety valve means bad ignitor. (I am certain of this information).
Oct 16, 2015 | Kenmore Kitchen Ranges
Heater will not ignite
  1. Do you have a standing pilot style heater = Milivolt
  2. or is it an IID = Spark style ignitor
  3. Or... Hot surface Ignitor = glows red hot like an auto cigarette lighter?
Most common problem I have come across over the last few weeks, is pressure switch not closing, meaning - dirty filter. Try cleaning your filter: backwash or rinse cartridges.
  1. is pilot staying on, and burning well?
    1. If so, is htr's gas valve in ON position?
  2. Do you hear sparking?
    1. If No, then one of the safety switches is keeping heater from firing...
      1. Toggle switch - on/off
      2. Thermostat - turned up high?
      3. Pressure switch - closes circuit when pump comes on
      4. 2 each high limits
      5. Fusible link / roll out switch
    2. If yes, either gas valve is off, is bad or the Ignition module is bad? Some call it grey box.
      1. You will need to test for voltage at the common and MV posts of the gas valve - 24 to 28 volts. If voltage = bad gas valve; if no voltage = bad IID Module (Intermittent Ignition Device)
  3. Do you see a bright red glow in the burner tray area?
    1. If yes, either fuel supply is off, or Ignitor has worn out and the glow is not hot enough to ignite raw fuel.
    2. If no, check voltage at Ignitor - depends on make and model of heater- could be as low as 24 volts and as much as 110 volts. So... No voltage at the supply wires = bad sending component, again depend on brand and model, could be ignition module, could be circuit board?
    3. If yes voltage, bad Ignitor
      1. Again, this is if fuel supply is confirmed.
Good Luck
May 08, 2015 | Teledyne Laars Laars Lite 2 Pool Heater...
Whatdoes an oven igniter do as opposed to the oven bake igniter?
Initors work with oven safety valves and open gas safety valves when the amp draw changes as the ignitor heats up. Ig niters light the flame and then become a thermocouple and send back confirmation of ignition to the central control. The model above uses a glow bar ignitor which is wired in series with the oven control and safety valve. The most common mistake when diagnosing the ignitor is working is you see it glowing. But that does not mean it is strong enough to open the bi-metal inside the gas safety valve which requires a minimum of 3.5 amps to bend the bi-metal so it will release gas to the burner. -PawPaw.
Dec 12, 2013 | Amana ACF3355 Gas Kitchen Range
My gas oven (Frigidaire Gallery) is not preheating or coming up to temperature. The broiler and stove top burners work fine.
Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
Jul 18, 2011 | Frigidaire Ovens
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
Jul 14, 2011 | Magic Chef Ovens
Our MAGIC CHEF gas range has a pilot light that comes on, the ignitor comes on, but the oven does not work heat. Any ideas would be appreciated.
First off, decide which you have, a pilot lite or an igniter coil. In electronic controlled units, when the oven won't light, as long as there's gas available, 98% of the time the igniter is bad, even though the old one may glow and seem to be very bright, it could have a small hairline crack in the ceramic, which would not allow the proper amount of electrical current to travel to the gas oven safety valve, which would then make it open and release the gas. A new igniter works almost every time.
Jul 03, 2011 | Magic Chef 31000 Gas Kitchen Range
Turn on oven and temp stays at 75. No gas comes on and igniter does not glow. Replaced igniter and still have same problem. Have 120 volts in and out of igniter and it does not glow. Help?
Lets take a look at yer wirin diagram.
You have 4 components in the oven heating circuit. The control, the ignitor, the safety valve, and the sensor.
Ignitor has been replaced with no help right? Did you check for continuity of the gas safety valve?
themobilian_1659.jpgIf yall have nothing (open circuit) between the two terminals then the valve is bad. Won't no ignitor glow with an open safety valve. Next thing:
Sensor: 1100 ohms @room temp. Erratic or open sensor and the oven won't KNOW what the temp is. themobilian_1660.jpg
Finally and I say finally because yall want to replace the most expensive part which is the control last, after yall know for sure it ain't all of the above mentioned components.
I have some service manuals and more HERE
Mar 03, 2011 | Maytag CWG3100A Gas Single Oven
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
Oven will not ignite glow plug an orange color
Just because the igniter is glowing doesn't mean it isn't bad. You also have a safety valve at the bottom rear of the oven that could be bad. If the igniter doesn't get hot enough to ignite the gas the safety valve will not let the gas in. If you don't have a separate broiler from the oven, check and see if broil works if so then its the "glow plug".
Hope this helps and good luck.
Dec 16, 2009 | Kitchen Ranges
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
Frigidaire FGF316 Gas Kitchen Range Logo
222 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
