Home | Toshiba | RS-TX20 DVD Recorder | System constantly re-...
Toshiba RS-TX20 DVD Recorder
Problem for Toshiba RS-TX20 DVD Recorder
System constantly re-booting
By Stevenjen on Nov 25, 2006
My unit reboots automatically at different intervals. Sometimes you can watch 5 minutes of TV and sometimes 30 before the picture freezes, pixilates and then the system reboots. Everything works fine when the system is up. I tried resetting the system, unplugging it, and have checked to make sure that it is not over-heating. Any other ideas?
Solution #1
posted on May 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
While this post is very late to answer this question, here is where I found a solution with the DVD still inside. When I used this solution, the whole system reset and worked.
http://www.tivocommunity.com/tivo-vb/archive/index.php/t-277275.html
"I had the exact same problem tonight. I put in a DVD and it locked my Toshiba RS-TX20 up. It simply wouldn't respond to anything but unplugging. Then it went into this infinite loop of trying to power up.
I finally got it to boot:
Hold the eject button on the unit continuously while it boots up (be patient!). It didn't open the tray until a couple minutes into the powering up process. After I took out the disc, it booted up normally at the next try.
I am guessing that there's a very small window during the booting process that the dvd drive isn't locked and you have to push the eject button in that small window to get the tray open. Since we don't know when the drive is unlocked, the best bet is to hold down the eject button continuously.
I hope this helps!"
Popular Solutions for Toshiba RS-TX20 DVD Recorder
Questions and Unsolved Problems for Toshiba RS-TX20 DVD Recorder
Do you recommend Toshiba RS-TX20 DVD Recorder?
Answer
Answer
intermittantly freezes on playback of recorded shows.
Answer
this is not the first time this has happened. toshiba rs-tx20 dvd recorder - it will work fine for a... (More)
Answer
the same picture appears on the tv screen but at the unit, I get no lights for power, and I can't... (More)
Answer
I've been moving my home movies to DVD's and after several discs successfully downloaded, 2 discs... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba RS-TX20 DVD Recorder:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
