I have a sharp ar-m160
It is flashing error code L6. Does anybody have an idea what i need to do to fix the problem.
  • kevin545 Nov 12, 2008
    I pressed the print switch and did get the code 10. Do you have an idea how much it would cost to replace the laser unit?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
If you press the print switch while the l6 code is in the window you will get a second code. more than likly it will be a 10 that means your laser unit is bad & needs to be replaced.
Posted on Nov 12, 2008
  • Roger Binsfeld Nov 12, 2008
    are you a tech if not you will want to take it to a tech this is a job for a tech. the price would vary depending on where you live.
    rog
My sharp ar m160 is showing L6 what do i do to clear it
The error L6-10 refers to the laser mirror motor not turning.
The only thing you can do is turn the machine off & then back on. If the error re-occurs then, unfortunately, the laser motor assembly would need to be changed out. This would only be done by an authorised dealer who would be able to source the parts.
Hope this helps.
Good luck.
Dave.
Jan 13, 2017 | Sharp Office Equipment & Supplies
Sharp -Ar-m160 flashing L6 error
look like you might need to have the print head replaced. tha is what houses the LASER
Feb 04, 2015 | Sharp Office Equipment & Supplies
Part Number of laser diode (Mitsubishi), Sharp Copier AR-M160.
L6 code means the motor is not working. You need to replace that, which means replacing the entire laser module. They can be gotten cheaper used from your local sharp dealer. I know this because I work on these things every day, being a certified sharp tech. L6 code means motor lock or motor sense dead, not necessarily laser dead.
May 25, 2010 | Sharp (SHRAM900) All-In-One Laser Printer
I have an AR-M160 and have an L error. How can I
this L6 ERROR IS USUALLY TO DO WITH THE POLYGON MOTOR IS IT L6-10
Jun 11, 2009 | Sharp AR-M205 Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
L 6
L6 error on AR-M160 - Polygon motor problem.
I would suggest repairman service for this one as it requires stripping the unit down.
Try reseting the error first though.
"#" "interupt" "clear" "interupt" "1" "4" "start key"
Jul 02, 2008 | Sharp AR-M160 Laser Printer
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Feb 20, 2008 | Sharp AR-M160 Laser Printer
Error report
I think L6 is the fuser unit replace fuser unit as not warming up or the control board.
Thanks J
Sep 18, 2007 | Sharp AR-M160 Laser Printer
820 people viewed this question
jasbo
jasbo
