Question about Ricoh FAX2500L Plain Paper Laser
Red light lit next to wrench icon on top panel.
The fax can not recieve faxes, only send.
It's a Ricoh 2500L that I can't seem to locate a manual for... even at the Ricoh website.
  • 183 Answers
Tell me yours e-mail address and i will sent you the manula the red lit may be a toner end lit
Posted on Jul 16, 2009
Have you tried the simple things yet? Have the sender send you one page with a single word on it like TEST.... See if that works.
May 05, 2014 | Ricoh Aficio SP C240SF
Ricoh 2500L fax won't print. Toner is okay. Can send faxes.
sending is dfrnt relation with toner.have u recv any cnfrmatry slip after sending fax.?
Aug 26, 2013 | Ricoh 2500l/3000l/4500l/i Toner
Our Ricoh 1800l has stopped recieving faxes how do I fix this?
our Ricoh 1800l has stopped recieving faxes how do I fix this
Feb 15, 2011 | Ricoh SFX2000M Plain Paper Laser Fax
I need adf roller parts
I can't find Fax 2500L are you positive of the model number and Ricoh as the manufacturer?
Aug 03, 2009 | Ricoh FAX2500L Plain Paper Laser
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
No fax tone giving if this fax mode only
Using "on hook" you should hear a dial tone, if you have one then dial a known good fax number. It could also be in manual receive mode. -Carl
May 05, 2009 | Ricoh FAX1900L Plain Paper Laser
You must have your resolutions set much higher than the default.
Scanner: Go to "user tools", "Scanner features", "scan Settings", "default Scan settings", "resolution".....set to 200dpi
Fax: Resolution may be set to "detail" or "fine" by default , rather than "Standard" either light lit?
This would dramatically reduce memory capacity.
To set this to default standard resolution is a needlessly difficult task. You can either manually turn it off when sending a fax or change the default "user parameter settings" for the "home position". You can find instructions in the Fax manual (Advanced settings). Download here:
How to set parameters and understand them (sort of ) is on page 80
How to set home position is on page 86
Mar 09, 2009 | Ricoh Office Equipment & Supplies
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Fax function doesn't work
check your phone lines.then connect it to the on hook dial.if dial tone is not there you may need a service engineer.
Apr 05, 2007 | Ricoh Aficio 2018D All-In-One Laser...
93 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
