-   my monitor is a e172fpt dell model and when turns on only dysplay a white screen , not video on the screen, could some body helpme -   josefdez6225
Nov 26, 2008
-   Using the on screen menu I can adust the vertical position of the image and all is good. However when the monitor turns back on or wakes up from sleeping the image jumps back up and I have to manually adjust it again.
It is annoying to manually adjust it twice a day.-   Guest
hello sorry i don't know the answer but i did not think that this problem is related to failure of cmos battery or the failure of memory ic in monitor.
if any one give any suggestion plz send me the solution also
thanks rameshchandra722@hotmail.com
my moniter turned on and off when i power on. after turning the power on and off few times, the...
(More)
my moniter turned on and off when i power on. after turning the power on and off few times, the moniter comes on. However after about a month of that my monitor won't even turn on Thanks
Acer AL 1716W recently just starting having vertical lines appearing and then it freezes and comes...
(More)
Acer AL 1716W recently just starting having vertical lines appearing and then it freezes and comes up no signal and yet internet connection is ok because my laptop has not disconnected internet, pulled out plugs and check properties which show no problems. Vertical lines now appear all the time when turn on computer. How do I get rid of the vertical lines?
