Question about Alpine MRP-M450 Car Audio Amplifier
Alpine mrp-m450 Amp won't stay on
Hi, I just installed an Alpine mrp-m450 mono amp in my car. The amp light goes on when the Alpine HU is turned on but goes off after 1-2 sec. I've checked all my connections: Amp wired to battery with 8 gauge. RCA inputs OK. 8 gauge ground. Speaker connections ok to Alpine sub at 4 ohms. I thought it would be the remote turn on, but I'm getting a constant 12 volts to the amp turn on connection. I even wired it directly to an accessory 12v lead but it won't stay on. Has any one else had this problem with an amp? The amp and subwoofer are new. Thanks for any help.
  • Anonymous Feb 19, 2009
    i have the same problem,,but the funny thing is that for the two or three seconds that it is on it puts out i can hear it playing then it just goes out let it loses power or somthing ...did u figure out wht was wrong with yours???
Im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Posted on Jan 08, 2007
    Novelist:
  • 133 Answers
Sounds to me like it might be the remote turn on because the first time i installed it, it did the same thing, and i found out that there is two blue wires coming out the stereo, one with a white stripe, i connected it to the blue wire, and it didnt work, then i connected it to the blue and white wire, and it worked. Well hope this solves your problem, goodluck.
Posted on Jul 06, 2009
Subs cut in and out
The amplifier may be going into protect mode (even briefly) because you are driving them too hard. Back off on the volume and see whether the problem goes away.
Mar 11, 2017 | Alpine MRP-M1000 Car Audio Amplifier
Wiring alpine amp and sub
To wire your 4 ohm dual voicecoil to a 2 ohm mono load - all positives to + on amp.... all negatives to - on amp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
Amp light flickering
do you have a capacitor its like an extra battery, if you turn the volume way up with cvr's pullin big power, it cuts out because theres not a steady flow of power.... hope this helps
Jun 30, 2008 | Alpine MRP-M450 Car Audio Amplifier
Power turns on briefly
Sounds like a protection problem. A relay may be stuck, or there really may be an internal problem you cannot see. Take it to a shop to have it bench tested independent of your vehicle.
May 20, 2008 | Alpine MRP-M450 Car Audio Amplifier
Not enough bass
its prolly the deck, did you try turning the alpine's input gain controls up...
its not the wiring, if the wiring was insuficient, it would just melt...
you might also see if you could adjust the bass frequencies or crossover frequency, the crv might just have a different resonant frequency then the rav 4
May 16, 2008 | Alpine MRP-M450 Car Audio Amplifier
My Alpine m450 amp light is on but no sound
make sure your RCA's are plugged into the input and not the pass through
Mar 28, 2008 | Alpine MRP-M450 Car Audio Amplifier
MRP-M450 puts out no sound to the subs
The amplifier may be overloaded, check to see if it can handle 4 OHM loads and 2 OHM loads. if it turns off at high volume the amp may be overloaded. if so try a 8 OHM load. if it still turns off it may be an internal problem.
Jan 07, 2008 | Alpine MRP-M650 Car Audio Amplifier
Alpine MRP M450 Problem
Sounds like it is getting too hot and a thermal overheat protection switch is shutting it off. Check to make sure your gain isnt over 3/4.
Dec 05, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
Just died out..
Have you determined if the problem is with the amplifier or the subwoofer?
Have you checked the wiring to make sure that there are no loose connections?
Oct 18, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine MRP-M450 Car Audio Amplifier Logo
693 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
