Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Suds lock I believe that I have suds lock. How do I repair it.
  • 20 Answers
Washer desudser in unit or cold water
Posted on Feb 10, 2009
Whirlpool duet f35 error-suds error
Maybe this will help, but I'm not sure
Condition:
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Check:
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump
Check Pressure Switch
Check CCU
Dado
Sep 13, 2015 | Whirlpool Washing Machines
Tip
Sud mean
over dose of detergent detectd during the wsh cycle ////// the motor control unit senses a suds lock condition by analyzing the current draw on the drive motor . if "sud" is displayed a potential suds lock is detected . this may signify a badpump an extra heavy load excessive detergent or excessive suds.................
on Aug 05, 2010 | Washing Machines
Do you know what problem 5d or Sd means
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Sud message
Sud: Suds lock (overdose of detergent detected during wash cycle)
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
Possible causes/procedure:
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU)
Duet service manual and repair photos HERE
Jan 15, 2011 | Kenmore Elite HE5t Washer
My washer stops and suds flash on the display
or kinked.
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
Use your tech sheet for diagnostics it is behind that panel the Handy Hippy showed you how to take loose (see above link) Use this MANUAL for Duet sport as a guide for repairs
Thanks for using fixYa
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is suds lock what does it prevent the machine fr doing
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Thank You
Sep 06, 2010 | Washing Machines
Half way through the cycle I get a suds on the display then the other code I get is oe. Any suggestion on what is wrong?
The Suds code is a SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • Check & Clean Drain Pump and Filter of foreign objects and debris
  • Check Drain Pump
  • Check CCU
Nov 09, 2009 | Maytag Neptune Washer
Showing sd
sd= SUDS
your pump has locked down with suds due to over soaping.....
Wait a while let the suds coaless, and put in a spin cycle.....
you may need to unplug the unit for a while let the error clear
when it does do a full load of towels with out soap
id be willing to bet you will see plenty of suds in the agitate cycle
now cut way back on your soap believe it or not this model only needs a table spoon per load
this will clear up the SD in the futur
remember you bout this unit to save water
1/6 the water 1/6 the soap
hope this helps
have a great day
Oct 25, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Calipso Clothes Washer (yea, that one...) Trouble code ''CA'' means I have to remove tiny cloth clog that faults the water pump, (I'm getting good at that one), but now I have a ''''SL''...
SUDS LOCK:
The motor controller senses a suds lock condition by analyzing the current draw on the drive
motor. If a potential suds lock is detected, the control tries up to 3 times to clean out the unit
with a mini-cycle. See Use and Care Guide for more information.
“SL” is displayed if suds are detected but the unit is unable to clean out suds. This may
indicate a bad pump, an extra heavy load, excessive detergent or excessive suds.
Press STOP/CANCEL to clear the display. MANUAL
Sep 13, 2009 | Whirlpool Washing Machines
Calypso displaying SL or5L messages, did you get it fixed?
I see at least 2 of these a week. 9 out of 10 times, it's the pump. If the u-joint is bad, it will put strain on the motor causing it to think it's overloaded as well.
Jul 12, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
237 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
