Question about Acer TravelMate 4100 Notebook
Mouse tracking problem on my touchpad
When I drag my finger across the touchpad, the cursor stops, jumps, or disappears. Nothing has spilled on the keyboard and when I do manage to place the cursor over an icon, I can open or close it.
Help!!
  • 93 Answers
1.See if it still same if you try use USB external mouse?
2.maybe you can try this:
swtch off your laptop, use 99% pure isopropyl alcohol to clean the mousepad carefully, DO NOT spray directly onto mousepad, spray to a cleaning cloth and wipe the the mouse pad carefully.
3. Could be virus
Posted on Nov 14, 2008
Dell pc pointer jumps while and after typing
Make sure your fingers/palms aren't grazing the touchpad as you're typing. What's probably happening is your hands are too close to the touchpad, making the computer think you're using the mouse, and thus jumping the cursor around.
Jan 18, 2014 | Dell Inspiron Computers & Internet
Jumping Cursor
Make sure your palm or more than one finger is not covering the touchpad. Laptops manufactured before 2013 did not understand "Multi-touch" on touchpads. Use only one finger on the touchpad and problem should be solved. If it doesnt, the touchpad is damaged. Buy a mouse.
Nov 01, 2013 | Dell Inspiron Computers & Internet
Cursor jumps around
Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Jan 28, 2013 | Dell Inspiron dncwix12 Notebook
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
While typing a story, the curser will jump backwards, and if I don;t realise it, I am typing between a previous word. Sometimes the cursur disappears from the page completely, and I have to use the mouse...
What's happening is that your finger(s) are touching/dragging across the laptop's TouchPad
while you're typing,
and thus the cursor's position in the document is being randomly reset/repositioned
while you're typing.
Solution: disable your Laptop's TouchPad, and use a mouse for cursor control.
Solution: tape a 3x5 index card over the Touchpad while you're typing.
Solution: type on a computer with a real keyboard, not the chiclet-type keyboard you (and I) are using.
Mar 28, 2011 | Computers & Internet
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
How do you highlight with a touchpad
With most touchpads you hold down the left mouse button to select then move the cursor with the other hand by pressing a finger on the touchpad and dragging it. Be sure your touch pad is not disabled - usually a button near it with an indicator LED.
Dec 12, 2009 | Toshiba Satellite A505-S6970 Notebook
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Steven
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Acer TravelMate 4100 Notebook Logo
272 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
