Lands Phones Logo
Posted on Nov 12, 2008
ANSWERING MACHINE HAS SO MUCH STSTIC, I CANNOT HEAR THE MESSAGES.
wstatler
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 12, 2008
wstatler
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
3478
Points
26
If this is an old tape answering machine, I bet the tape is worn out or the head is dirty. I would go purchase a new digital answering machine for around $30
HOw to retreive messages from RCA Telefield model 1000
To retrieve messages from the RCA Telefield model 1000 answering machine, follow these steps:
  1. Press the "play" button on the answering machine. You will hear a beep and the machine will start playing your messages.
  2. Use the "skip" and "repeat" buttons to navigate through your messages.
  3. To save a message, press the "save" button. To delete a message, press the "delete" button.
  4. If you want to keep a message, write down the date and time of the message and the caller's phone number.
If you are having trouble retrieving messages or the answering machine is not working properly, you may need to reset it. To reset the RCA Telefield model 1000 answering machine, unplug it from the power source for a few minutes and then plug it back in. This should reset the answering machine and clear any issues.
2answers
Phone says " mailbox is full" but all recordings have been deleted and it has 0 recordings showing.
Without know what voice mail system you are talking about you cannot be helped.
How do i erase messages
To erase a message while it is playing, press the ON/OFF ERASE button. The
answering system announces, "Message Erased" to confirm the message has been
erased.
To Erase All Messages: When the answering system isn't playing or recording messages, press and hold
the ERASE button until you hear the "Messages Erased" announcement. Release the
button after the announcement. This feature allows you to erase all old messages
but not new messages. If you do not have any messages, the answering system
announces, "Zero Messages."
User Manual: http://www.home-electronics.net/USER-GUIDES/29875_DOM_EN_AN_IB.pdf
1helpful
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
How can I receive remote messages
When you are away, you call your number. After the answering machine asks you to leave a message, punch your code and listen to the instructions (hear new messages, hear all messages, erase message, de/activate answering function, etc.).
Hope it helps.
I accidentally deleted an answer I wanted to hear on an AT&T 1719 answering machine. I read the manual and noticed that messages cannot be recovered. Who makes an answering machine with an "undelete"...
Once you delete a message on a consumer answering machine, it's gone. The only option is to save all messages until the machine signals that it's out of room. Even with a tape-based answering machine or professional voicemail systems, once you erase a message, it's gone.
Lost my manual and cannot remember how to get messages remotely
Since I have not idea what exact model you have this may or may not work... I hope it helps, as it is for a Uniden answering service phone.
Remotely Operating Your Answering Machine
Note: The answering machine will only playback messages for four minutes and then it returns to the command waiting mode.
To continue playing your messages, press [#] then [2] again within 15 seconds.
To operate from a remote location, use any touch-tone telephone and follow these steps:
1.) Call your telephone number and wait for the answering machine to answer
2.) During the greeting message, press [#] and enter your PIN code within 2 seconds;
How to enter a PIN
To play your messages from a remote location, you will need to enter a two-digit Personal Identification Number (PIN) or PIN Code.
Press the MENU soft key. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
Enter a two-digit security code (00-99) using the number keypad [0-9].
Press the OK soft. You will hear a confirmation tone.
You hear "To play incoming messages, press pound-two. For help, press pound-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following:
# then 1 Repeat a Message
# then 2 Playback Messages
# then 3 Skipping a Message
# then 4 Deleting a Message
# then 5 Stop Operation
* # then 6 Answering Machine On
# then 7 Memo Record/Stop**
# then 8 Greeting Record/Stop**
# then 9 Answer Machine Off
# then 0 Help Guidance
Playing back messages on the AT&T 1725
Press the mail box button quickly to hear only new messages. Press and hold until you hear the system respond to hear all messages. Press again to stop playback.
3helpful
How to retrieve messages from the answering machine ..remotely
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
