Question about Dell Inspiron 600M Notebook
Registry file failure
Everytime i tey to get on my laptop it goes to the windows loading page and then a blue page shows up and says " stop:c0000218 {registry file failure} the registry cannot load the hive (file): \systemroot\system32\config\software or its log or alternate it is corrupt, absent, or not writeable beginning dump of physical memory physical memory dump complete contact your system administrator or technical support group for further assistance." what can i do to fix my computer? im at a total loss as to what has happened to make it do that.it wont let me go to the log in page either. it goes straight to the blue screen with all the writing.
    President:
  • 2,961 Answers
If the last suggestion i posted didn't work, you need to put in your Windows CD on boot up and when it asks if you want to repair or install press 'R' for repair, this should repair any damaged registry files and Windows files.
Posted on Nov 12, 2006
SOURCE:
My Gateway file c0000218 registry failure the registry cannot load the hive /SystemRoot/System/32/Config/System or its log or alternate is. It is corrupt, absent or, not writable.
it sounds like you have a bad sector on the part of the hard drive containing this file. you need to let chkdsk complete the scan as it may be able to recover the corrupt file and isolate the bad sector so its not used again.
if this works backup the system as your hard drive may be failing.
Mar 09, 2012 | Gateway MT6821 Notebook
Blue crash screen
http://support.microsoft.com/kb/830084
This page is Microsoft's answer to your question.I sure hope this helps?
Mar 10, 2010 | HP Compaq Presario SR1538X (PX799AA) PC...
Packard bell versa e400
Hi
files in system32\config\ are missing or corrupt.
there is a back up stored by default at c:\windows\repair
you can copy the contents of windows\repair folder into system32\config\ and it should solve the problem, you can do it with the windows installation cd by using the recovery console.
Go into the repair folder enter the following commands in repair console
cd windows (press enter)
cd repair (press enter)
copy *.* c:\windows\system32\config\ (press enter)
files should be copied
type exit, quit or restart or reboot to restart the computer.
May 22, 2009 | Dell Inspiron B120 Notebook
Blue screen: Stop: c0000218 {Registry File
Hi.
You would have to have the operating system repaired or completely re-installed.
Please rate me. Thank You.
Apr 16, 2009 | Acer Aspire 5315 Notebook
System crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
Mar 26, 2009 | Acer Aspire 4315 Notebook
Inspiron 600 m Dell blue screen
Keep pressing F8 as the computer starts up, select "last known Good Configuration" from the menu.
Jan 22, 2009 | Dell Inspiron 600M Notebook
STOP: C0000218 {Registry File Failure} The registry cannot load the hive (file):\System Root\System32\Config\SECURITY or its log or alternate. It is corrupt, absent, or not writable.
to fix the problem, you need the Installation cd, put it in, start the setup, and enter repair console when the first blue menu comes up.
In repair console, your going to have to copy the windows\repair directory to system32\config
to fix the problem.
After the files have been copyed, Well maybe might be better if you only copy the SECURITY file. so no login details get changed.
Then restart the pc and see if it worked. If not your going to have to perform a repair installation from the xp cd.
If you need more asistance, let me know. Good luck.
Mar 29, 2008 | Microsoft Windows Server Standard 2003 for...
This sounds like a previously removed piece of sofware, either a peice of a programme spyware, virus or malware, thats still got the start up files registered. Download this programme, it's very good, it's free and has no spyware attached, it will remove all traces of unused registry files and temporary files. http://www.filehippo.com/download_ccleaner/ If you still have problems click Start>Run and type 'msconfig' without quotes. This will bring up a window; click the startup tab and see if there are any unrecognised programmes on start up that you no longer use.
Nov 09, 2006 | Dell Inspiron 600M Notebook
Dell Inspiron 600M Notebook Logo
392 people viewed this question
Clive
Clive
Alun Cox
