Question about Rockford Fosgate 800.2 Car Audio Amplifier
800.2 hooked the amp up in a different car and it blew the b++ fuse so something is crossing the power to the ground. maby if i would of used a fuse in the last car i wouldn't have this problem. any ideas? thank you for the help
  • 631 Answers
Did it only blow the fuse AFTER you applied remote voltage?
If you're going to try it again, do so with nothing larger than a 20 amp fuse.
Posted on Nov 12, 2008
I have a memphis mcd 1000. It started smoking and blew both fuses. I replaced the fuses now when I hook power to the amp sparks real bad like the power and ground are touching
I hate to tell you this, but you have something major. Shorted. Check your wires and conections with a meter. The bad news. Is your amp may be a goner.
Apr 28, 2015 | Memphis Car Audio & Video
My nitro 1600w four channel amp will not power on at all, no glow or power. i gave good ground and power and fuses are good. it worked in the car that i bought it off of
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Doub .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-1600w-four-channel-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Sep 07, 2011 | Nitro BMW-486 Car Audio Amplifier
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
Soon as i try to connect the power and ground starts sparking and my fuse blows by the battery. I changed the ground cause i thought that could be it plus i tryed installing it in another car that had an...
your inline fuse wouldn't blow if there was just something wrong with the amp. the amp fuse would blow if that was the case. something is faulty with your wiring. you probably have the wires touching somewhere or are in the wrong terminals at the amp or on the wrong battery terminal. or your power wire is grounding out somewhere. its not the amp. its your wiring
Mar 16, 2010 | Car Audio & Video
Amp blows fuses
Are you using the correct fuse? if so,
more then likely, you don't have a good ground. Try grounding to something else that has more direct connection to your frame. If that doesnt work, try getting larger power cables.
I had the same problem with my 2500w xplodes all I had to do was get a thicker cable for the ground and battery connection. What was happening, was it was needing more power then the wire and fuse could handle, so it would blow the fuse, since the higher you have it, the more power it needs to feed the watts.
I would try grounding it directly to the frame on a good part of the frame before spending another $70 on new power cables though.
Mar 09, 2010 | Car Audio & Video
New amp
Something is def. wrong. did you check the fuses on the amp after the light went out? probly have a bad connection somewhere. check ground wire and power make sure they have a good connection and arent cut up and shorting out.
Oct 21, 2009 | Pioneer Car Amplifier GM-7100M - Mono Bass...
Is my amplifier finished
check first the fuse of your amplifier set maybe blown up then check also the switch of amp.
Aug 15, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
The lights blink 1 2 3 just as his....
hook up power to power and ground to ground, and remote wire to power amp or anttenea on radio
Jun 06, 2009 | Infinity 7540A Car Audio Amplifier
Powering up problem.
It,s the mounting the screws are touching something in the radio when bracketed and yes you probably blew the power diode in the radio, it can be fixed pretty easily. Try a fuse on the ground and the hot next time.
Jan 30, 2009 | Cobra 29 LTD CB Radio
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Rockford Fosgate 800.2 Car Audio Amplifier Logo
87 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
