Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Adding toner to canon imagerunner 2200
A canon imagerunner was donated to our church. There was no operators manual and we need to add toner. Are there any instructions on how to do this?
Thank you.
  • 168 Answers
If you have the toner open the front door take toner out of box turn the blue handle on the right side of the copier down which will move thr hopper. pull out the hopper till it stops . take the bottle and line it up so it snaps in place when it snaps in a little tab should pop put pull the tab till it says stop . This process opens the top of the hopper and bottom of the bottle then using your thumbs push the tabs on the front which closes the bottle back. then give it a little extra push and the boyyle will click off
Posted on Dec 08, 2008
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
Do you want to refill toner for ir 2200 model?
The best way would be to buy bulk package of toner, it comes aprox 1 kg package.
Open the top cover on toner station and fill the toner station.
Jul 22, 2010 | Canon imageRUNNER 2200
"where is canon imagerunner 2200 drum located on printer", I need to clean it.
you open up the front door of the copier..... the developer handle down and the toner loading hand open . to the left of the toner holder there is a small panel with a single screw in it. remove that screw and the whole drum assembly should slide out
Jun 13, 2010 | Canon ImageRunner 2220N Copier
Error Msg
its a waste toner catredge full indication error.replace the waste toner catredge.
Jun 15, 2009 | Canon (6981A002AA) for imagerunner 2200,...
How to add toner
Open the front cover. Towards the right side about half way down, there is a plastic lever. This will rotate to release the Developer/Toner Unit away from the Drum Unit. Pull the Unit should stop before coming all the way out (unless someone has removed the stopper) Please use the correct type of Canon Toner as it fits on top of the Unit and unlatches Toner cover to add the toner. (Canon Type GPR-2). The instructions should be in picture format on inside of front cover.
Jun 10, 2009 | Canon ImageRUNNER 330s Copier
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Adding/changing toner
You can get an operators manual from It can be a difficult website to navigate.Good Luck
Mar 26, 2009 | Canon imageRUNNER 210S Copier
Networking imagerunner 2200
First, plug the printer into the network with an Ethernet cable. Then, go into the configuration page on the printer's display and print a configuration page. Look for the IP address. When you have that, go to the computers that need to connect to the printer. (Note that this tutorial is for Windows XP, I am not familiar with Vista but this should give you a basic overview.) Go to Start > Printers and Faxes. Click add a printer on the left hand side of the window. Select a Local printer attached to this computer, and unselect automatically detect. On the next page, click create a new port > TCP/IP port. Type in the IP address of the printer. Then choose the driver you are going to use, you should be able to find the IR 2200 driver under canon pretty easily. If not, go to and download their drivers. Once you do this, print a test page and it should print. You are then fully configured.
Please rate, Thanks!
Jan 21, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
265 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
