Question about Refrigerators
Frost in Freezer
I have a Frost Free LG fridge that is only a year.
The top Freezer has frost like snow and the cooling vents freeze right up so I can't turn it down.All the food has a layer of snow like frost on it.
I have defrosted it and cleaned it a couple of times but it ends back to this every time.
  • 2 more comments
  • thecoot Nov 12, 2008
    Thx for the quick reply ,I'll look at that tonight.
  • thecoot Nov 13, 2008
    Freezer fan seems to be working,but haven't taken the back off the fridge yet to see the other options you mentioned or which ones they even are.
    Excellent mike thx again ,I'll check them tonight or this weekend.
  • Anonymous Mar 20, 2014
    de frost problem there is some snow in freezer
  • 1,122 Answers
It is a defrost problem,could 1 freezer fan not working2defrost heater in freezer not working3 defrost sensor in freezer not working and 4 defrost timer not working,if you have a volt meter you can check to find out which one it is,the easyest is to just look in the freezer and see if the fan is running to move the cold air,you might have to hold the freezer door button in to check it,let me know what you find-mike
Posted on Nov 12, 2008
  • MIKE major Nov 13, 2008
    you take the panel off inside the freezer back wall to check the heater and temp. sensor,the defrost timer is either inside the frig. on the temp. control console or on the back of frig.behind the metal panel-mike
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
I have only had my frost free fridge freezer 1 year could you tell me why my freezer only freezes the 2 bottom trays and not all 4?
Can you provide a model number and Make? Example below
Cooling stops? Frost buildup on walls in freezer or fan inside or outside fridge not running? Let me know by answering my post here, Thanks John T. Appliance 911
Apr 30, 2015 | Frost Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
Frost free freezer keeps frsoting up. It's a french door refrigerator with the freezer on the bottom. The vent is not blocked. The door has not been opened frequently. The appliance is only 9 months...
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Also note that
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up......
Hope this helps
Jul 28, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer freezing up in the bottom vents, the fridge is not cold enough. the freezer works great. there is no drainage in the drain pan in the bottom. it is a frost free refrigerator.
The heater for the frost-free isn't functioning. Have a technician check the circuitry on the heater for breaks, or even a defective heater!
Feb 12, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator will not cool . the freezer is freezing but it seems to be building up frost.
You have an auto-defrost issue. Cooling the fridg side comes from the freezer side. If you see frost on the inside back of the freezer side, it's clogging the cooling vent to the fridge side. You need to have the defrost parts replaced. Parts cost less than $50. Installation is around $250.
Jul 13, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer is working but the firdge part is not cooling.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Samsung Refrigerators
Refrigerators Logo
210 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
