Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Sony KP-65WV700 DVI-HDTV Issue
This TV works flawlessly on all inputs except for DVI-HDTV (Video 7). However, when I connect either a digtial tuner or a HTPC to Video 7, the picture will be perfect for a short period of time (less than 30 mins) and then it will litterally collapse and the screen will go blank. The power light will continually blink 4 times until the set is powered on. If the set is immediately powered on after it problem occurs, it will work fine for a few minutes and then the problem will reoccur.
Thanks,
David Scott
Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
From here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Posted on Dec 20, 2008
Have isolated problem to vhf/uhf connection point. white lines flash in pic. w/a popping sound & if they stay for very long there is a buzzing as in over white or over modulation. problem shows when...
Problem seems with main tuner in this tv as other AV inputs working fine so please replace main tuner (TU2) to solve this issue.
There are two tuners mounted on A board TU1 and TU2, please replace TU2 and part number would be written on tuner itself.
TV is approx 10 years old so I would recommend that do not spend lots of money on it.
Thanks.
Feb 27, 2011 | Sony KP-53HS30 53" Rear Projection...
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
I get curved red lines and then screen goes completely red and no sound
This is symptom of defective red picture tube in TV that needs to be replaced.
Let me know if you want to replace it by yourself to provide you part number info or call tv tech to do the job.
Thanks.
Nov 30, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony KP46WT510 picture goes back and fortto horizontal color bars
The pictures show the result of a bad terminal input board. You can verify this by checking the inputs. Connect devices to the board and try different inputs. You will most likely find this problem on the tuner and component input were your DVI and composite video will be ok. If it is the same on all inputs replace the A board
Jun 24, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony rear projection tv no picture
you need a new video board
i have one that might fit
cody
573-433-1925
Nov 02, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Kp-65wv700
You need to adjust Green screen drive control your green tube could be shorting out.
Sep 14, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
