Question about Canon MP830 All-In-One Printer
Alarm light is flashing and can not print
I have turned the printer on and off and tried the reset button.
The alarm light and copy lights keep flashing and the error code says 6A00
THanks for your help
  • ktdid4 Nov 26, 2008
    Yes, I have the same problem. Website says I have to bring it in for service.
  • JDTec
    JDTec May 11, 2010
    Error 6A00: an error occurred in the AP motor during the purge operation.
    Canon says to check the purge unit, logic board and the sheet feed unit.
    You need the service manual to take unit apart.
  • 4,041 Answers
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I had the fatal 6A00 error on my out-of-warranty MP830 and I was ready to give up and buy a different printer. Per Canon website it says that you need to send it for repairs.
Goggling the error message, I was able to find a solution to this error that doesn't require sending the unit to Canon. . The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
Based on the postings, there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere. 2) there may some paper stuck somewhere around the printhead and or the purge unit or 3) there is a build up of gooey ink on the purge unit.
The gooey ink turned out to be my problem and apparently quite a few others. Following someone else's advice, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. I also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, I plug the unit back in and worked fine. Problem solved!
Posted on Mar 29, 2008
SOURCE: Flashing copy/alarm buttons. Error code 6A00.
buy a different copier
Posted on Jun 17, 2008
SOURCE: Error Code 6A00 Copy button flashing along with
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
if that doesnt help i ll tell u what worked for me
I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Posted on Jun 08, 2009
  • 3422 Answers
SOURCE: Canon MP830 error code 6A00
HI,
Please the pixma off and open the lid.Now manually slide the cartridge-tray to the left.
Use a piece of tissue to clean the base-pad where the heads are stored.See if it is stuck in a kind of upward position and look if the mechanism that moves the tray is released if not then touch it and it will be loose. Remove all ink residue, move the tray back to its most right position and close everything.
Let me know if you still get the same error.
Thank you
Posted on Aug 13, 2009
komguy
  • 2306 Answers
SOURCE: Receiving error code 6A00, and alarm light is
That error says the purge unit is broken. You will need to have the purge assembly replaced.
It's # QM2-3032-000 but a shop should replace it for you.
Posted on Dec 04, 2009
I have a canon MP530 waste ink pad near full. what should i do?
Press the OK button.
The service call error, indicating the waste ink absorber is full,
is likely to occur soon.
Once the waste ink absorber becomes completely full, printing
cannot be done until the waste ink absorber is replaced.
To reset it:
With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT
release the buttons). The COPY button lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset
buttons. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange
and COPY in green, starting with Alarm LED.) "CANON Idle" is displayed on the LCD.
4) When the COPY button lights in green, press the Stop/Reset button the specified number of time(s) according to the function
listed in the table below. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately,
Alarm in orange and COPY in green, starting with Alarm LED.)
4 times - Waste ink counter
resetting
Hope that helps!
Aug 19, 2010 | Office Equipment & Supplies
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
ALARM light flashing, wont let me print.
hold down stop/reset button for 7 sec. If that doesn't work try holding it down for 14 sec.
Dec 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
It is one of two things.
a bad ink cartridge (the chip located on the gold part of it)
or
bad USB cable.
IF you have a spare cable simply change them out.
If you are refilling your cartridges, it is time to replace them.
Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Alarm button Flashing, will not perform any function
Turn your printer on. On your computer, go to:
Start
Printers and Faxes (or Control Panel - Printers & faxes)
right click on your printer icon
click on "Printing Preferences"
in the dialog box, click on "Maintenance" tab
click on "View Printer Status"
in the dialog box, click on "Options"
then deselect the "Enable Status Monitor" option (remove check mark)
When the alarm light on the printer blinks and the printer won't do anything not even scan, you can press the reset button (on the printer) for 10 seconds and then, while holding the Reset button down, you simultaneously press the OK button (on the printer) for a few more seconds. For some reason, I sometimes need to do it several times before the alarm light goes off but so far, it always unblocked the printer in the end.
At that point, do the "Enable Status Monitor" as explained above. (put check mark back)
When you need to check the levels, you can either look at the cartridges physically or enable the status monitor (if you are still using 'legal' cartridges in one or more slots).
Google for "Chip resetter for MP530" or go on Ebay for this product.
Jan 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error 22
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jan 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp780 -waste ink near full??
Dear mr perfect,
Few days ago I have answered the same question about this for Canon MP700. Here is my answer:
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon IJ Forum
Dec 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
I have a Canon MP700 Printer. The message "waste tank nearly full" appeared. As I couldn't find any help in the manual I removed the ink cartridges to look for a "waste tank". ...
Dear miggsy,
Regards,
Source:
Canon Inkjet Printer Forum
Dec 05, 2008 | Canon Office Equipment & Supplies
Alarm light flashing, please wait message
Can only try
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Jun 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
324 people viewed this question
old marine
old marine
