Question about Dryers
Whirlpool ultra care 2 dryer. Stopped heating yesteraday. It spins but does not heat up. Please help.
  • eqjdg Dec 17, 2008
    the repair man came out yesterday and did not take off the back panel at all. Without checking it first, he gave me an estimate for the ignitor and then took the whole inside apart. Once he tried the ignitor, and it came on,....he said it was then coil and another part. It is a gas dryer.
    I cannot afford a new dryer right now, but would like this one fixed. Is it worth fixing for over $200, or to get a new one. The machine is three years old! The drum rotates, but there is no heat.
    Oh yes, the vents are all clean and good ventilation throughout.
    Genius:
  • 1,122 Answers
The heater box fuse has failed,most likely from a clogged vent on the back of dryer or wall,you can remove the large back panel to get to the fuse it is on the top of the heater box on the side,it is a small fuse,you can get one at sears .com click on parts put your model number in(inside dryer door)and get your part,let me know how you do-mike
Posted on Nov 12, 2008
My whirlpool gas dryer will not heat. It only spins.
If the dryer won't heat but does run, it is more likely to be the gas ignitor assembly, assuming there is gas available to the dryer. If the thermal fuse was bad, the dryer wouldn't start at all.
Jan 06, 2010 | Dryers
We have a Whirlpool Ultimate Care II gas Dryer that is getting intermittant heat. Sometimes it will heat, sometimes it won't. Iin addition, today it stopped rotating as well. Ideas?
Could just be a matter of wires coming loose. The movement and vibration of the spinning could have shaken wires loose. look for any wires not connected to anything.
Nov 06, 2009 | Whirlpool GGQ8831L Gas Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 07, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool dryer
Sounds like the belt is either broken or has slipped off. Please post the model number so I can try to assist you, if you need help replacing it.
Feb 24, 2009 | Whirlpool Dryers
Clothes dryer doesn't spin
The way most domestic clothes dryers are made, it's usually hard to determine that the heating part works without the drum turning.
But, chances are, the drum belt is broken.
Please give the specific model number of your unit for a more complete response.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
562 people viewed this question
Top Dryers Experts
