Guest
Rank: Apprentice
Rating: 0%, 0 votes
Above suggestion is good. As add-on, you can observe the defrost timer to see if it is turning. Place a mark at the current point and then check it later to see if it has moved. Another thing is to look at the terminal leads to see if any of them are burnt (blackened).
To test the thermostatic switch (bi-metal switch), remove it and place it in a freezer or bag of ice (when this switch gets real cold, it closes and you will get continuity). Use a meter to test continuity. Keeping it connected to meter, put it under a faucet with running water (as the temperature rises, the switch will open). You should observe it go from continuity to no continuity.
