Question about Music
2 keys(reeds) are not working ,my keyboard is yamaha DGX200,how to open it
Plz tell me how to open the keyboard & clean the keys I have a Yamaha Clavinova CLP 920.
One note sticks - it does not return when pressed.
  • Anonymous Mar 14, 2014
    Every time I play a sequence of keys on the Matrix 12 one note fails to play but then if I press it again it returns to play. How can I solve?
It is a design fault. A technician advertising on the net informed me i can get it fixed by him and yamaha will pick up the fee.
Posted on Nov 14, 2008
Yamaha psr 295
Hi, This is probably due to worn rubber contacts. The sound is switched by pressing a key which in turns press a carbon contact on the PCB under the key. In time these wear out and need to be replaced.
Firstly open up the keyboard and locate the rubber contacts, check to see if each one is seated squarely, if they are not seat straight then this can create the problem you mention.
If all are OK then you will need to replace the strip which is causing a problem.
Spares are available from many sources including :
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=16049
Jul 20, 2013 | Yamaha PSR-295MS Portable 61-Key...
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
Yamaha psr 550
When PSR550 keys stop working, or are intermittent, in any arrangement, this can be fixed (with work). There is probably TINY dust or debris which prevents a clean key contact from taking place; you must unscrew and open the PSR550 up like a ****, then unfasten the bottoms of the keyboard circuit boards. You can figure out how to move them without totally disconnecting them. You will observe how a tiny rubber-mounted contact presses against an interleaved circuit-board connection pattern to make contact when a keyboard key is pressed. Any dirt or crud on the contact area of the circuit board must be removed, because it will prevent the conductive contact from bridging the circuit cleanly and fully. I used 91% alcohol and QTips to clean all contact surfaces. It took me a couple of disassemble/assemble cycles to get all the keys clean and working, and the PSR550 back together. But first download the service manual: it will show you how to open it and access various components. You will see that the keyboard switches are much like calculator buttons on a TI-83 calculator. They are pretty well enclosed, but you will see how much dust can settle in just through various humidity conditions, especially if you take it to gigs. Good Luck.
Nov 24, 2011 | Yamaha Music
Yamaha W 7 keyboard problem I have a Yamaha W 7 keyboard. Every now and then when I play the note A left of middle C the note keeps replaying or re-hammering while holding the key down. This started a...
under the keyboard there is a switch for each key, try to clean it whit water and a smooth paper. I have Roland keyboards and it happens after playing a lot.
good notes
Feb 07, 2011 | Yamaha Portable Keyboard
How to store music we play on yamaha psr i425??? and how to transfer dat to pc? plz help
You will need the CDROM that should have come with the keyboard when you purchased it. On it will be the drivers that need to be on the computer for it to use the usb. The link to the manual is here:http://www2.yamaha.co.jp/manual/pdf/emi/english/port/psri425_en_om_a0.pdf Please look at page 86. If you don't have the CDROM you may be able to download what you need by contacting Yamaha by email through this link and asking:http://www.global.yamaha.com/support/contact.php I hope this helps.
Oct 23, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Yamaha keyboard not working
We have a Yamaha keyboard YPT-330 note E and F sharp not working why?
Feb 25, 2010 | Yamaha Music
My psr-230 keyboard does not work well, some keys
The key contacts proabably need to be cleaned.
One has to disassemble the unit being very careful of cables. Do not force anything.
The contacts are usually black conductive rubber "pills" under silicone rubber domes. These are often in strips covering several key contacts.
Clean both the pills and the circuit traces on the board they contact with 99% isorophyl alcohol and Q-Tips.
Jan 23, 2010 | Yamaha Music
How doI open a Yamaha P120 to fix sticky keys?
I've had the very same problem twice so far. The only solution I figured is to simpy purchase an equivalent key (contact Yamaha service in your country for this) and to replace the broken one. The reason why the key doesn't work smoothly as the other one is not dirt therefore any cleaning won't help. The key is cracked deep in the place where it's attached to its 'axis'. So you'll need to remove all the screws and unmount the cover (it needs a sideshift to open once the screws are removed), be careful with the speaker wires. However you'll need firm moves anyway. Opening is tricky and gets me surprised anytime I do it so you'll need some courage :). Replacing the key is even more tricky. You'll have to remove the broken one by pulling it horizontaly (use some force, it's broken anyway). Placing a new key you'll need to uplift the 'hammer' and then slide a new one. I'm sure you'll figure it out once you see it with your own eyes (it's really hard to decribe but not so hard to do it). Hope you'll do fine. I haven't tried glueing the crack for I doubt it would work for long. Good luck!
Jan 28, 2009 | Yamaha Full-Size Keyboard
Music Logo
542 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
