Question about Kenmore 24 in. 15149 Built-in Dishwasher
Kenmore Dishwasher My dishwasher fills with water and then stops. I hear the cycle timer continue all the way through the cycle. I pulled the screen off the bottom inside of the dishwaher and stuck my hand in the diswasher drain. Originally I felt and cleared what appeared to be a torn up rubber band. I feel a thin straight metal pin that I can rotate and I believe it causes the pump to rotate as well. Once I do that the dishwasher will run normally thorough a complete cycle...BUT I have to go through this ritual about every other cycle. My theory (uneducated as it is) is that the water pump loses prime until I rotate the thin metal pin. I do not have any water leaks. I've checked. Do I need a new water pump? Or is it something else?
    Novelist:
  • 135 Answers
If you have either dry bearings in the motor or sticky grease buildup in the pump bearing/seal, it can cause the motor to stick rather than rotate on startup. More likely to be greasy crud buildup. The best you can do without disassembling the entire unit is to circulate a good degreaser product in a wash cycle, such as 409 or PurplePower. On the off chance (very small chance) it would degrade plastic parts, only run degreaser wash cycle for 5 minutes or so before draining it and running rinse cycle.
Posted on Aug 02, 2007
Kenmore dishwasher filling up with water but never spinning and cleaning
I have had this happen before on my dishwasher. The timer inside the door is stuck or the contacts on the timer may have broken off. When you turn the knob on the dishwasher it sends power to a timer, which continually turns until the end of the cycle. This timer is attached to a bunch of arms which close contacts to send power to different parts of the dishwasher during different times in the cycle, now if the timer is worn out and missing parts of its gears or missing some of the armatures the machine will only get so far along in the cycle until it doesn't know what to do next and just stops. Hope that helps
Sep 06, 2012 | Kenmore Dishwashers
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
It starts then stops. never completes the cycle. it shuts down. it will drain thats it.
If the cycle didnt complete check the following:
Water-heating cycle
* On some units, the pause is timed and the unit continues after the allotted time.
* On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place doing one function continuously the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Sep 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Our neff dishwasher has suddenly started to go wrong. When you switch it on a push a setting, it fills but does not wash. After about 10 mins it even drops the powder cube but still has not washed, it just...
Water-heating cycle
Timer
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Aug 02, 2009 | Dishwashers
I have a kenmore dishwasher. While it was in the
hi...
If the cycle doesn't complete, check these....
if still it doesn't fix your problem then see whether any error codes are generated....
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective F2 High water level · Plugged/Bad water pump
· Defective water inlet valve F3 Thermistor fault · Open thermistor
· Bad wiring to thermistor F4 Fault with water fill (only on machines with level-controlled fill)
Note: Lights blinking, pump running and controls dead indicates an over fill fault 1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
i think these details would definitely help you.....thank you...
Jul 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher stalls
Water-heating cycle
Timer
May 31, 2009 | Bosch SHU4006 Dishwasher
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
Water-heating cycle
Timer
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher pump motor stops
Water-heating cycle
Timer
Water-heating cycle Manydishwashers heat the wash and/or rinse water to a higher temperature,as the cycle calls for it. In these cycles, the dishwasher pauses afterit has filled with water, waiting for the water to reach the pre-settemperature. What happens next, depends, as follows:
  • Onothers, the cycle can't continue until the water reaches the highertemperature. If you have this type of dishwasher and the water isn'tbeing heated (say, because of a problem with the heating element orthermostat), after the unit stops at the heating cycle, it nevercontinues. When you repair the heating-system problem, the "cycleproblem" is fixed too.
Timer Timersdon't often fail. But if every other part of the dishwasher seems to beworking properly and the timer knob seems to be stuck in oneplace--doing one function continuously--the timer may be at fault.Dishwasher timers can't be repaired. If yours is defective, replace it.
Dec 10, 2008 | GE Dishwashers
Dishwasher problem
1. Water-heating cycle
2. Timer
Water-heating cycle
Timer
 thanks for using FixYa
Feb 10, 2008 | Kenmore 65924 Electric Dryer
Kenmore 24 in. 15149 Built-in Dishwasher Logo
216 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
