RAM error with RAM Installed
Hi there
I have a pronble, with this pentuim 2 computer , I recently upgraded the video card and CPU, but now the PC says there is no RAM in it.
Specs : P2 400 Mhz CPU, Asus P2VB Motherboard , 64 MB RAM , Windows ME , 128 Mb ATI Rage Card,
I changed the ram to another machine and the ram is fine.
Please help
Thanks
Roger
  • 10 more comments
  • softwaresale Nov 12, 2008
    Sorry for the spelling mistake
    Hi dave
    the video card is stand alone (not onboard) fits onto an AGP slot on the board. I used to run 128 MB as 64 MB RAM ? why is it halfing?
    thanks
    Roger
  • softwaresale Nov 13, 2008
    Hi dave
    The previous video card was an S3 3D/2X Card, I replaced the processor with the same type of 400 mhz pentuim 2, the new card is an ATI Rage 128 MB , The halfing wasn't related to shared memory because the old card didn't say it was sharing in the bios
    Thanks
    Roger
    Hi dave
    Will try the solution as soon as a i get to my PC
    Thanks
    Roger
    hi dave
    I tried this , still didn't work. Pc Still Beeping
    Thanks for trying
    Roger
    hI DAVE
    BEEPS : LONG _ LONG _ LONG _ LONG_
    Thanks
    Roger
    Hi dave
    Its not the pc 133 ram or Pc 100 ram that is causing the ram problem cause I had a PC 133 ram in the pc and worked fine, I don't know what is going on. The CPU and fan is ok
    Hi dave
    Thanks
    Roger
  • softwaresale Nov 14, 2008
    Hi Dave
    I will try , but i am getting another board
    Thanks
    Roger
  • David Preston
    David Preston May 11, 2010
    Roger,
    Sorry this is taking so long.
    This is one I'm having to RESEARCH on. Turns out this is a 1st Generation AGP board and I'm trying to narrow down the reasons for your symptoms.
    In order to figure this out I'm going to need to know the details of your upgrade. This Board can take both socket type and slot type CPU's.
    I need to know what you previous CPU was and what you replaced it with
    As well I need to know what Video card you HAD and what the new one is.
    The Memory issue (where the system only sees half) sounds like a shared memory problem with your video card but This is usually only with integrated Video cards, but I suppose if your old one was an OEM card(One made by ASUS it might still be able to share memory)
    Give me an update on the details and I will try to get you up and running again
    Thanks
    Dave
  • Frank
    Frank May 11, 2010
    what is the specification for the RAM.?
  • David Preston
    Roger,
    Was the video card you relaced an integrated(Built into the Motherboard) version?
    Or was it a standalone, Fits into the slot on your motherboard?
    Once I know this I can try to figure out why your computer is no longer detecting your ram.
    thanks
    Dave
  • 144 Answers
It may be because your video card is using shered memory
Posted on Mar 31, 2009
    Genius:
  • 1,605 Answers
There are serveral critical question need to ask
1). what is the FSx (CPU Bus frequency at ?
2). what is the BFx (CPU Bus Frequency Multiple at?
3). voltage selected for the DRAM?
4). what was the original CPU ? (spec.)
5). non ECC SDRAM PC100@ 100Mhz max.
Posted on Nov 13, 2008
    Sergeant:
  • 207 Answers
Roger,
The problem clearly isn't a video sharing as I was originally suspecting.
First let me inform you that even your upgrades are several generations behind the current mainstream, Not a problem as long as they are sufficient for your needs. I don't know about the CPU but the Video card is no longer supported by ATI.
Ok lets get down to the Nitty Gritty
First lets remove ALL of your cards from the PC
Video card, any PCI cards and if you have them even the ISA cards
Now remove the ram modules and the CPU
OK we should be starting with a bare Motherboard
Check to make sure that all of the power connections are attached in this case it should be a single 20 pin ATX connector
With that done make sure the IDE connectors are oriented properly there is a notch on the drives connectors that lines up with a key on the ribbon cable.
make sure this cable fully seats into the Motherboard and the drives connector(Try to route the cables so that they are tucked out of the way if possible)
Now repeat the procedure with the floppy drives ribbon cable and connector (If applicable)
Inspect the CPU make sure the heatsink and Fan are attached and mounted Flush to the CPU card
Now insert the CPU into the Slot1 making sure to pay attention to orientation. If I read right you replaced the processor with one of the same speed? if so you don't need to mess with the jumpers that are onboard for the CPU.
If it DOES need a different FSB setting the open up the user manual(Link below if you no longer have it) and find and set the appropriate settings
http://dlcdnet.asus.com/pub/ASUS/mb/slot1/via693/p2v-b/p2vb-102.pdf
attach the CPU fan leads to the proper header on the Motherboard
Now check out the RAM slots, there are 2 latches at either end of each slot. Don't put the ram in yet move the latches into an upright position. The should be firm in place you should NOT be able to wiggle them. If there is some PLAY in them we might have just found your ram problem. These latches sometimes jar a little bit up and thus PREVENT the ram modules from seating properly. Any latches that had some PLAY in them just give them a bit of downward pressure (Don't have to FORCE them) until you here and/or feel it click back into place. Now fold down the latches and insert the SDRAM cards once in place fold the latches up until they LOCK into place and hold the ram steady. If any SLOTs are empty fold their latches up too (There are little sensors under these latch arms, that if ANY are down it prevents the Rams address bus from energizing to protect any improperly seated modules)
Now insert your Video card, If there is a latch at the back of the AGP slot make sure that engages properly (Don't worry if there is not one SOME of the older ones didn't have them) just make sure the card seats down all the way into its slot.
Now install any other cards I had you previously remove from the system install any wires from the front panel header that might have been removed or jarred loose, make sure that your case fans are attached to their headers.
I think your ready to give it a try NOW.
When you boot up it may pause asking you to confirm a memory checksum error as the Memory level should be different from the LAST time it boot press what button is says to do so to continue. After the ASUS logo blinks off screen press <Delete> to enter BIOS make sure the Video card setting is for AGP and not PCI press <F10> to save and exit.
This SHOULD have you up and running if not comment back and I'll try to assist you further.
For your information the last Generation of Winows supported with drivers for this board are Me/NT/ and 2000
When you are next ready to upgrade I would recommend getting a more modern motherboard with integrated graphics (If cost is an issue at the time) It will improve your upgrade and support options
Hopefully this helps you
Dave
  • 1 more comment
  • David Preston
    David Preston Nov 13, 2008
    OK you say your getting beeping when your trying it?
    pay Attention to the beeping its kind of like a Morse code specifically for PC's their called POST (Power On Self Test) codes if you can tell me WHAT the pattern is. I can narrow things down to what component is affected. It should be a pattern of short and long beeps.
    When you tell them to me use this format Long beep = L a short beep = S and a pause =
    so a pattern of 3 short 1 long and 3 short with pauses in between would look like the following.
    SSS L SSS
    looking forward to helping you further
    Dave
  • David Preston
    Roger,
    I searched for a bit to find THAT particular Beep code and found 2 possible answers.
    1.) Prob: One was that this beep code indicates a CPU fan error
    Solution: Double check the CPU fans connected to the Header just above and towards the left Side of the CPU's slot
    2.) Prob: Bad or improperly seatted RAM
    Solution: Try to reseat or replace you SDRAM modules (Verify you are using compatible modules) For you its simple If it isn't SDRAM PC100 then you've got the wrong RAM
    If these don't resolve your problem heres another way you can NARROW it down
    Replace your NEW CPU with your Old one if you get a different post code or if the machine boots up you KNOW the fan mounted to the NEW CPU is bad.
    Hope this helps you
    Dave
  • David Preston
    Roger,
    I'm afraid you've stumped me on this one. You can try contacting Support at ASUS and see if they cant tell you what THAT particular POST/Beep code means.
    If your SURE that the 2 things I mentioned on my last post are fine, then my last best guess would be it has something to do with the Jumper settings that control the Processor Front side bus or the memory timings. (Information on adjusting those are in the manual which I gave you a link to previously)
    These settings are adjusted by jumpers on your board (So they have to be Physically changed) Whereas on more modern boards they are adjusted from within the BIOS or even sometimes automatically by the board itself.
    Good luck
    Dave
  • 189 Answers
As I figure your problem, it seems that you upgraded your motherboard, and video card, but the other part are still the same with your previous P2, if you upgrade your computer better to upgrade everything, cause if your still using the old part like the RAM, the upgraded computer will not detect that part.
Thanks.
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
I have this old laptop and its called a compaq (presario 2500) well yesterday i brought the sims3 game for it because the laptop dosent have internet. When i installed the game it says windows xp has to...
Thanks for using fixya.
My name is Carlo.
Your computer might not pass the system requirements that's why it has an error. Or, you can try installing it one more time and check if it will work. Computers do mess up sometimes.
Here's the system requirement of SIMS 3:
Desktop PC (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1 GB of RAM
GPU: 128mb Video Card (GeForce FX 5900 or Radeon 9500)
Desktop PC (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 1.5 GB of RAM
Laptop (Windows XP + SP2):
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
RAM: 2 GB of RAM
Read more: http://pc.ign.com/articles/939/939410p1.html#ixzz10TQHijZi
IF your computer does not pass the system requirement, then you cannot play sims3 in your computer.
I hope this helps. Thank you for using fixya
Please leave your comment and ratings. Thanks
CARLO
Sep 24, 2010 | Computers & Internet
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
Im trying to fix up my wife's Dell Inspiron B130 instead of buying a new computer. what is the best processor, and video card upgrade i can do?
You don't want to upgrade the cpu. As for the video card it can't be changed as its build into the laptop motherboard.
I would highly recommend that you instead upgrade the ram memory on the laptop since it will give you a bigger performance increase than a new cpu or video card.
The machine only has 256MB of ram, get atleast 512MB or 1024 /1gb of ram and it will work much better.
Jul 09, 2009 | Dell Inspiron B130 Notebook
Any help building a media center box
Are the video card drivers installed? depending on which card it has its either a Ati card, sis or Nvidia. you can get the drivers for it from here
http://support.acer-euro.com/drivers/desktop/aspire_t310.html
That is most likely it - the cpu is enought to run video. I have 512Mb on my old laptop and it plays video perfectly I think your going to upgrade this ones memory so it wont be a problem.
Cpu is good enought to play dvd and video.
Video card if no drivers are installed then it will be very sluggish and poor quality. if even after the right drivers are installed depending on what brand and model card it is, it may be too slow or the issue maybe in codec and media player.
try installing FFDSHOW into the computer and see if it improves (it wont help if the drivers aren't installed for the video card so make sure that is solved first) Download ffdshow latest here http://www.free-codecs.com/download_soft.php?d=4786&s=50 (for other users: its the latest version at the time of posting on may 18. check google for new version)
if you need to find out what video card the computer has you can use a program like http://majorgeeks.com/download4181.html <- everest home free.
May 18, 2009 | Acer Aspire T310 PC Desktop
Upgrade P5RD1-VM motherboard to the gaming PC
Your pc is not for gaming right now because you are using Intel Pentuim 4 Mother board and CPU. Amd Athlon is best for gaming. I have a AMD Athlon 4200+ X2 with 4gb Ram and Nvidia 6800 256mb OC. to upgrade your computer to a gaming pc. you will need to switch your motherboard and cpu for best performance on games. in order to do that, you might need a different case for your new motherboard. because the one you have might not be right for the AMD Athlon motherboard unless you have a custom made computer. other than that everything is set for you. if you have less than 1gb ram you might want to add more. because the games they are coming with right now is 1gb minimum or required.
i hope that answers your question.
Thank You
Dec 08, 2007 | ASUS P5RD1-VM Motherboard
Adding RAM
Those beeps are a series of codes that are telling you what is wrong. You can look up the beep codes and the LED codes on the back of the PC at this site: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm That's the long route. The short route is that you likely either bumped your video card and need to re-seat it, or the memory you installed is not completely seated. Try re-seating it if you haven't already.
Sep 19, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
1,068 people viewed this question
David Payne
David Payne
