Question about Video Game Consoles & Games
Ring offire on my xbox360 - Video Game Consoles & Games
  • 470 Answers
Have you done an internet search for this: How to repair the dreaded ring of fire on my XBox?
If so, you are not alone!
The problem has become prevalent enough that you will find different methods of fixing it online. You might be familiar with the towel method. I see that one a lot when I was searching for this.
You might think that the towel method is worth a try. After all, it is free, right?
I'm sorry to burst your bubble, but I highly recommend against using that method.
Why do I NOT recommend the towel method?
Well, when you searched for "How to repair the dreaded ring of fire on my XBox," you most likely were searching for a safe method of repairing your XBox, a safe, quick, and permanent method.
If that is what you were looking for, then toweling your XBox fits one out of three. It is a quick method. And that is about the only positive of that method.
It is NOT safe, nor is it permanent.
You run the risk of frying your XBox, which I don't think is what you want to accomplish. It also is not permanent, with the longest lasting fix reported at 2 days. I'm sure you want a fix that you do once and that will let you get back to enjoying your XBox 360 again without the constant worry of when your XBox will flash red again.
The one safe, quick, and permanent method that I recommend is getting a reputable guide that deals with what you searched for, namely, how to repair the dreaded ring of fire on my XBox.
When you go searching for a reputable XBox 360 repair guide, a good way to gauge if the guide will work for you is to see if they have a sample video for you to watch. When it comes to fixing electronic equipment like your XBox 360, it is always good to be able to see what you need to do.
To help you out, I have researched many of the guides out there.
There was one repair guide that just stood out to me. I liked the layout of their site, it was easy to follow, and their videos were just awesome. They had HD quality videos, making it super easy to follow along.
Find out which guide was #1 by visiting my page on the Red Rings Fix.
Article Source: http://EzineArticles.com/?expert=Amy_Yang
it will works,, please rate it
Posted on Nov 16, 2008
My xbox360 goes on red ring when i play it
there are many different kind of "red rings"
If they are all red, it means that your av cable isnt being detected
if there are 3 red, its a hardware failure
2 means that your system is overheating
For more information, check out this: http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Good luck, if I helped you, please give me a positive review :)
May 26, 2011 | Video Game Consoles & Games
My 360 has 3 rings the rings are red and it wont turn on
The three red lights mean that your XBOX360 is experiencing hardware failure. This is caused by overheating of your XBOX. Contact Microsoft and have them fix the problem. They have given free extended warranty for three red light problems. If you have bought your xbox360 within 3 years, you're in luck.. They will fix your console for free...
Mar 13, 2010 | Microsoft Xbox 360 White Console
It freezes when you turn it on and shuts off. and when you try to turn it back on, instead of the green ring a red ring surrounds the xbox symbol.
It sounds like the RROD. If your XBOX360 is still under warranty, you can call Microsoft and they'll fix it. If not, you can either ship your XBOX off to be fixed by Microsoft or another company or try fixing it yourself. I fixed my red ring of death with a clamp fix (http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm)
Jan 01, 2010 | Microsoft Xbox 360 Console
Xbox360 Elite Ring of Death
Ok, if the seller is asking for more than $30 for this damaged unit, i'd say NO but, if the seller will part with this handicapped unit for $30 dollars, i would by it and repair it. you can use the link below for the correct repair procedure that will completely fix the ring of death.
CLICK HERE FOR THE REPAIR INSTRUCTION FOR THE RING OF DEATH.
May 24, 2009 | Microsoft Xbox 360 Elite Console
Rings of death
the "3 rings of death" or the so called "3 red lights" is actually caused by GPU overheating and mainboard flexing. When you need to do is open your xbox360 (warning, this will void your warranty) add more cooling fan inside your xbox360, you'd want to use 80mm fans coz they fit perfectly. you can fit up to two 80mm fans inside your xbox360.
Also, if you notice that your xbox360's mainboard is warped you need to fix this by disconnecting all the connections from the board. then place the board on a flat surface. then use a hair drier to heat the board and flat it out. its kinda complicated. hehe, at least you now have an idea on whats causing the 3 red lights...
May 01, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 3-red lights may be caused by DVD drive? Help please!
your 360 is a first run off assembly. they were junk from the start. my warranty expired also but called microsoft and they said if the ring of death is related to the first run of 360s they willextend the warranty. exactly what happened to me. 8 days later they sent me a brand new 360 cause problems with the first run 360s can't be properly fixed. contact them tell them the problem and you will get a new one. hope this helps Tadster
Apr 15, 2009 | Microsoft Xbox 360 Console
Xbox360 rings of death red rings when i turn on the console. can you help?
If you only have two red lights that means your xbox is overheated I had this trouble and took mine out to the air compresser and blew massive dust out of it,It's been 2 months now no lights.
Jan 07, 2009 | Microsoft Xbox 360 Console
Xbox360 disc reading error
u should find out if its chiped or not chiped 360s dont play live cds unless they r burned
Nov 06, 2008 | Microsoft Xbox 360 Console
Xbox360
ring of death microsoft should replace it, take it where you bought it or send it back, call first and tell them its the ring of death.
Oct 18, 2007 | Computers & Internet
Video Game Consoles & Games Logo
73 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
