Question about Dryers
Ariston Dryer ASL70C makes a grinding noise as it turns..
You have to check the bearing of the drum.
Posted on Dec 02, 2008
Dryer is making a very loud grinding, scratching, irritating squeal noise while operating. When it is turned off and manually turn drum grinding noise still there. Any suggestions? I have an extended...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 22, 2010 | LG DLE8377 Dryer
Mashine make noise and vibrating a lot
Hi, your washing machine makes noises because all the clothes and other materials are not balanced evenly--one side is heavier than the other--causing the drum to hit the sides of the washer wall.
Sep 29, 2010 | Ariston Technologies Ariston AWD12 Front...
I have an ASL70C Ariston tumble drier that suddenly has stopped emptying the water into the water tray.the clothes are still drying but where is the water going
Einy Lane -- Water Drain question -- If your dryer is installed next to a drain the water can be plumbed into this drain. This does away with the need to empty the water container. Simply remove the top hose from its top fitting at the rear of the dryer and plumb the hose provided to the drain.
If a leak has developed in absence of using the drain hose feature, then the water is going someplace else. Unplug unit and then check behind it for the drain line being fallen down. If you need more help, please write back. User Manual can be downloaded without charge from Hotpoint website. -- SWT
Aug 04, 2010 | Dryers
The dryer is making loud noise
heatman101
er789
Jun 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is making a grinding noise when the drum turns
hi your belt is ready to give up take does it smell of burning if not it soon will take the name make and model to comet they will sort you another and they are very easy to replace you just open the back of your dryer make sure it is unpluged first take the old one off and just slide the new one straight on problem sorted
Apr 26, 2010 | Maytag SDG3606A Gas Dryer
Heating problem with Dryer Ariston ASL 70C
hi.
in top of the heater box there is a thermoswits back of this swicth there is a tiny little hole use a paperclip or similar an put it to the hole and press not to much until you hear a little click and the thermoswicth is reset. and your dryer can heat again:-) and DONT forget unplug the power to the dryer first.....
best regards
ls danemark.
Jan 30, 2010 | Hotpoint Dryers
Estate dryer makes ascraping noise when turning
heatman101
uioto
Dec 29, 2009 | Estate EED4300TQ Electric Dryer
Dryer doesn't want to run- makes grinding noise
its sounds like a worn bearing problem.with the m/c switch off ,turn drum by hand and see if it is hard to do so.if you get a gritty feeling in your hands or hear a grinding noise,then that is probably the bearing.
Jul 23, 2009 | Dryers
Estate TEDX640PQ0 electric dryer makes grinding noise when running and seems harder to turn drum
heatman101
Apr 21, 2009 | Estate TEDX640JQ Electric Dryer
Ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
May 20, 2008 | Dryers
Dryers Logo
250 people viewed this question
Top Dryers Experts
