Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
52'' GE Projection TV will not turn on
I have a 1999 GE 52" projection TV. I have had no problems until last week. I changed channels and the picture looked distorted and turned red. I shut the TV off and turned it right back on. As it came on I saw a flash of light thru the bottom black fabric covering the speakers. Then the TV went off and will not turn back on. Any suggestions would be appreciated. Thanks
Called a service technician. Found bad board and wanted $437.00 I bought a new TV
Posted on Nov 13, 2008
My 52 " GE Projection
Tv needs to be realined by adjusting the Screen Drive Controls to Tubes.
Located behind the Front bottom Panel on front of Tv.
Focus/Screen Control Block 3 on top for focus and 3 under them for screendives to each Tube R/G/B.
Jul 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
Speaker don't work
first try to reset the tv configurations and parameters.
if the problem still : test the speakers with a metrix then and the sound board/circuit and see what can u replace
plz do rate this post
Nov 30, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE 6OGW947 60 in Rear Projection T.V.
it is your provider not the tv, i had the same problem. they just seem to lazy to fhelp you.
May 23, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
5 blinks means problem in the AKB (video) and 4 blinks means problem with the verticle deflection. Try this to get the screen to display any recent faults then get back to me and let me know what it said. Press the following buttons on the remote.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
Jan 13, 2008 | Sony KP-41T65 41" Rear Projection...
HD PICTURE
Use your input button on your television's remote control.... you should have plugged the wires into the COMP 1 area on the back of your TV.  You will also need to make sure your red and white audio cables are plugged in as well (Five total plugged wires) Press the input button until you see COMP1 at the bottom of the screen... there you will find your picture and sound.
Oct 19, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
341 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
