Question about Dell E152FP 15" Flat Panel LCD Monitor
LCD Monitors I leave my computer on all the time, but I was wondering if I should turn off my LCD monitor, or is it alright to leave it on all the time to. I just bought my first LCD monitor and didn't know the best was to care for it. Thanks
First use screen saver every 5mins this will protect your lcd from burn .
never use wallpaper with very high contrast same reason keep away from burn
its better to turn off you lcd monitor if your not using it. saves energy =)
Posted on Nov 12, 2008
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
Hello, I took apart my system to move furniture around and to clean. When I reconnected everything, all was well except all white areas on the screen have turned PINK! I tried going thru the...
Hi
This is a problem with a high magnetic field hence you need to de-goz the screen. Or leave it un-used for some time and it will be alright by itself.
Maybe when you were shifting you have kept a speaker with big magnet around the monitor thats why this has happened.
Dont worry it will go bad to normal by itself.
Jul 16, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
On starting moniter shows out of range
One of three things wrong:
1. Cable on Monitor or Computer not plugged in. (Rarely a bad cable)
2. Wrong or corrupt driver. Go here BenQ Support Win 98 2000 and XP
3 Defective or unplugged video card.
J
Alright, now it is time for you to rate this answer and leave me a comment if this worked for you. J
Thanks for using FixYa - a4 THUMBS rating and POSITIVE TESTIMONIAL is really appreciated forthe FREE answering of your question.
May 08, 2011 | BenQ FP531 15" LCD Monitor
My monitor won't show the display even though it is turned on
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card. When the PC turn on there is any beep. If no beep then your RAM is alright. Problem in VGA Card.
Mar 21, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
Alright so, i've had the same monitor for the past 4 years, no problems at all (starlogic 17" LCD) and today it decides to start turning off and on, with a very distorted computer screen when it is on. now...
If you mean that it powers on and off without being connected to a computer, it could well be the power supply or the power switch. If you mean that the indicator lamp switches from amber to green without being connected to a computer, it could either be the power supply, or some of the signal-sensing circuitry.
Unless you're knowledgeable and handy, monitors are not generally considered field-serviceable or user-serviceable. The manufacturer probably won't even sell you the power supply directly - you'd have to go through a servicing company, and it will end up costing you around $100 (if not more) to repair your 4-year-old monitor.
Prices have come so far down that you might be better off just replacing the monitor. If you want an inexpensive alternative, my company sells refurbished 17" LCD monitors for $150, including free delivery in the continental US. If you'd rather take the opportunity to upgrade, we have 19 inchers for $225. Checkout MaverickSolutions.biz for more info; links to our pricing and products are on the third tab.
Aug 21, 2009 | Star Logic Monitor
E-yama 17" flat screen monitor
It sounds like the internal bulb in your monitor is going out. Some LCD monitors go through a slight warm-up period but it should not be 5-10 minutes. You may want to change your Power Saving settings to prevent from going into standby. Here's how:
Right-click in an open space on your desktop
Choose Properties
Click the Screen Saver tab
Down at the bottom look for the Power settings
Change the Monitor Standby to NEVER
Click OK
Good luck!!
Oct 01, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
Brightness issue
hi, try recycling the power, unplug the power and vga cable and leave it out for some time, then check.. let me know
Dec 05, 2007 | Acer AL1916W 19" LCD Monitor
Dell E152FP 15" Flat Panel LCD Monitor Logo
57 people viewed this question
Alun Cox
