Machine is blocked, Can anyone tell me how to unblock it? Thank you.
Try www.manualowl.com Best of luck. Jimmy
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
This is a dishwasher and it is not obvious how to access the drain pipe to clear blockeage. Can anyone help? Thank you.
