MY SAMSUNG DVR SHR 1040 HAS LOCKED UP. ONLY SAYS "SYSTEM STANDBY" EVEN AFTER UNPLUGING
You need to replace your harddrive in your unit. I have been working on these for the past 2 days and it seems it is a problem with a lot of them.
Posted on Mar 21, 2009
I forgot my password and I cannot do anything. What is the solution? SHR-1040 DVR security system.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Jul 09, 2009 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
I changed the passwors of samsung shr-1040
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
default value.
•Default Password is ‘4321’ .
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
mj
Apr 05, 2009 | Samsung 4 Channel Dvr
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung shr 1040
try resetting the system and reprogramming.
if that does not work you may need to have it repaired.
Mode Key + CH 2
default value.
mj
Sep 18, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
How to stop recording,without killing the power?
My record lock is turn off, but every time I press the record stop to stop record it takes me to the password screen where I must enter a password before I can stop the recording....This piece of xxxxx is stink. I hate my Samsung SHR-1040...I cant even talk to Samsung about it.....When I call, they transfer me to India and they dont even know what a DVR is......I told them DVR 10 times, but they keep repeating to me " VCR"
Nov 02, 2007 | Samsung 4 Channel Dvr
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
