Question about GE Dryers
Towels won't get dry in GE dryer
Have replaced sensors, heating element.  getting plenty hot. Is there a fan that pushes the exhaust out.
    Genius:
  • 1,122 Answers
There is a blower wheel that move the moist heat air out,i think you have a clogg on the dryer vent side or the wall vent side,they need to be cleared or the dryer holds the moist hot air in the dryer and takes forever to dry,let me know how you do--mike
Posted on Nov 12, 2008
Dryer gets hot, outside vent seems to have plenty of air coming out. Lint screens all clean. But the unit takes two cycles to dry and in the past it always dried in one cycle. Whats wrong??
Is this happening on automatic dry cycle or timed drying?
It sounds like your moisture sensor is "confused" and shutting down heat prematurely.This part can be replaced.
Also double check your exhaust vent for blockages or standing water or sagging or open pipe
Also , your heater element may be shutting on or off prematurely. Could be a high limit thermostat problem. Or there is obstuction causing over heat
hope this helps
Aug 15, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Takes three cycles to dry towels, displays 45 min. turns off within 30 min. still not dry
2 possible reasons, either the towels have not been spun at a high enough speed and are too wet, or the dryer is not getting hot enough because it is not switched to a high enough heat setting or there is a partial element or thermostat or humidity sensor failure. You should spin your towels as fast as you can, 1000 MINIMUM but 1400 or more is better. Did it ever work? Is it a new drier? Is it getting hot? 45 mins is a short time anyway to dry a full load of towels.
Jan 03, 2011 | Whirlpool Dryers
Why does the dryer take an hour and a half to dry a load of clothes
GE dryers usually have more than one heating element. Your machine probably has one failed heater and one good heater. The dryer will not get hot enough with only one heater working.
Unplug the machine! Check the heaters for continuity with a multimeter and replace if no continuity.
If the heaters are good, a faulty operating thermostat can also cause this symptom. It can turn the heaters off before the machine reaches the normal operating temperature.
Poor air flow can also contribute to slow drying. Check for lint buildup blocking airflow inside the machine and the vent duct.
Apr 28, 2010 | GE DBXR463EDWW Electric Dryer
Takes 4 hours to dry a load of towels. plenty of heat - just not drying
How damp are the towels? More moisture= more time to dry
Is the dryer full to the top with towels? There needs to be enough space to allow for air flow in and out.
Also check exhaust vent to make sure it is not blocked.
Oct 09, 2009 | Whirlpool GEW9250 Electric Dryer
I have almost the same problem... but I have plenty of heat.
If it's takeing that long and your element (coil) is that hot your exhaust is probablly blocked it will need to be cleaned out.
Oct 05, 2009 | GE DLSR483EE Electric Dryer
Electric GE dryer DBXR463ED2WW is not drying
The exhaust hose or piping is clogged, try cleaning it or replace it.
Mar 26, 2009 | GE Dryers
GE dryer will not dry towels
How warm is "warm"? If the clothes are warm to hot after 15 minutes of running but not gettign dry, you do not have a heating element problem. Sounds like you still have an air flow problem. Does the heating element cycle often? You may have lint clogged at he entrance to the blower. This would be out of sight from the exhaust. Try removing the exhuast hose and running it in air-only and feel the amount of air leaving. It should feel like a lot of air coming out. If not, you will need to check the condition of the blower. I had this same issue and ended up pulling the blower cover off and pulled out a very large amount of lint..it was almost completely clogged. Afterwards it drys really fast! Good-Luck.
PS If you do not feel comfortable accessing the blower, you should have a professional do it for you.
Mar 23, 2009 | GE DVLR223 Dryers
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
99 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
