Installation error i want to install vtp8.0.1 but when i click on .exe file, it shows error message that windows has encountered a problem and need to close after this installation will be closes.
    President:
  • 392 Answers
Test my way, before installation, please install this program: "Microsoft .NET framework 3.0" and then try to install your program, but don't forget, after installing the .NET framework reboot your system
Posted on Nov 29, 2008
How do i fix windows update error 1722
According to the error code 1722, it is actually a windows installer error. What we need to do is to fix the Windows Installer.
Try the following fix below...
(Please note that before trying any of the solutions below, you must be logged into your computer as an Administrator.)
  • Check whether Windows Installer engine is functioning.
  1. Click Start > Accessories > Command Prompt.
  2. At the command prompt, type MSIExec and press Enter. MSI refers to the Windows Installer.
  3. In the MSI engine is working, you should see no error messages. However, if you see an error message, note down the error. Search for it in a search engine such as Google to find troubleshooting solutions.
  4. Now try to install or uninstall the program again. If the problem persists, go to the next fix.
  • Check that Windows Installer service is not disabled.
  1. Click Start and type service.msc in the Search box and press Enter.
  2. The Services window is opened. Right-click on 'Windows Installer' service, then click 'Start'. The service needs to start without any errors.
  3. Now try to install or uninstall your program again. If it persists, try the next fix.
  • Check for latest version of Windows Installer.
  2. Once the command prompt window opens up, type MSIExec and press Enter. If MSI engine is working, you should see no error messages, and it should open a separate dialog box, which shows the MSI version.
  3. If the installer version doesn't show as version 4.5, download the latest version athttp://support.microsoft.com/kb/942288/
  4. Now try to install or reinstall your program again. If it still persists, try the next fix.
  • Reregister the installer engine.
  2. At the command prompt, first type MSIExec / unregister, then press Enter and type MSIExec / regserver
  3. Now try to install or reinstall your program again.
  • Clean your CD or DVD media.
  1. If you are trying to install the program from a CD or DVD media, use a CD or DVD disc cleaning kit.
  2. You can also gently wipe the silver side of the disc with a soft, lint-free cotton cloth. Make sure you do not use paper or other rough cloth as this can scratch the plastic or leave streaks that can damage the disk. Make sure you wipe the disk from the center outward and not circular motion.
  3. If you use a damp cloth or commercial disk cleaning solution, wipe the disc thoroughly before inserting into the drive.
  • Copy installation files to your computer.
  1. If you are using a removable or external media to install the program, copy the installation files from there to your computer's hard drive and then run the installation file from that location. It is usually called autorun.exe or setup.exe. If you are not sure, just check the Readme file in the setup folder about how to start the installation.
  2. Unless there is no .exe file present in the setup folder, we do not recommend that you run .msi files directly.
  • Terminating other programs running on your computer.
  1. Click Start and type msconfig in the Search box.
  2. One the 'General' tab, click 'Selective startup', then click to clear the 'Load startup items' checkbox.
  3. Click 'Services' tab, click 'Hide all Microsoft services', and then click 'Disable all'.
  4. Click OK, then click Restart.
  5. After the computer restarts, try to run your program installation.
  6. Once you have finished troubleshooting the problem, restart your computer again.
  7. Click Start, type msconfig in the Search box. Click on the 'General' tab, click 'Normal startup', click OK, then click Restart.
    Hope this helps!
Sep 09, 2011 | Computers & Internet
I am installing Quickbooks Pro 2005 on my Windows 7 computer. I got past the flash error but encountered a fatal error when trying to run quickbooks. Any fixes?
Try this:
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Jan 22, 2011 | Intuit QuickBooks: Pro 2005 for PC
I get an error message LifeCam.exe has
Problem with your Cam driver 1st You download Webcam Driver. Free Microsoft Camera Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 03, 2010 | Microsoft LifeCam VX-1000 Webcam
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
Oct 22, 2009 | Apple iTunes
Missing or bad msacm32.dll file attributed to many files not running, i.e., setup.exe, rundll32.exe, Explorer.exe and many more. is there any way to fix it without reformatting
The answer depends on why these files are missing.
Can you boot the computer at all or into safe mode?
If so you could run the "System Restore Wizard" and restore your system to a point before this problem happened. You can find the system restore wizard in the windows help.
This should fix the problem if has been caused by a virus or an accidental file deletion but if your disk had bad blocks or something then it might need replacing.
If this does not solve the problem tell us more about the exact error message and when it occurs.
Aug 16, 2009 | Computers & Internet
Error code 2352
http://service1.symantec.com/SUPPORT/nav.nsf/pfdocs/2003020714354306?Open&docid=2003020714354306&nsf=nav.nsf&view=pfdocs
To run the Microsoft Windows Installer if Norton AntiVirus was installed from the CD
  1. Insert the Norton AntiVirus CD into the CD-ROM drive.
  2. Do one of the following:
    • If the installation program appears, then click Browse the CD
    • If the installation program does not appear, then double-click the My Computer icon on the Windows desktop, and then double-click the CD-ROM drive icon.
  3. Double-click the MSI folder.
  4. Do one of the following:
    • In Windows 98/Me, double-click the WIN9x folder.
    • In Windows 2000/XP, double-click the WINNT folder.
  5. Do one of the following:
    • In Windows 98/Me, double-click the Instmsi.exe file.
    • In Windows 2000/XP, double-click Instmsiw.exe if you have Windows 2000/XP.
  6. In the next dialog box, click Yes.
  7. After the rollback has finished, then reinstall Norton AntiVirus.
    Follow the instruction in Reinstalling your Symantec program after a failed installation or after you see error messages to start the computer without any programs running on startup and then reinstall your Norton program.
If these steps do not fix the problem, then go on to the next section.
To run the Microsoft Windows Installer if Norton AntiVirus was installed from a downloaded version
  1. On the Windows taskbar, click Start > Find (or Search) > Files or Folders.
  2. Ensure that "Look in" is set to the drive where you downloaded Norton AntiVirus, and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, do one of the following:
    • In Windows 98/Me, type the following:
      instmsi.exe
    • In Windows 2000/XP, type the following:
      instmsiw.exe
  4. Click Find Now or Search Now.
    You might see many files with this name. Look for the file with this name that is located in either the Symantec_Norton_AntiVirus_2003 or the your Windows temporary file location depending on your version of Norton AntiVirus.
  5. In the Search Results window, do one of the following, depending on your version of Windows:
    • In Windows 98/Me, double-click Instmsi.exe.
    • In Windows 2000/XP, double-click Instmsiw.exe.
    This will undo the changes that were made to your system during the first failed installation.
  7. After the process finishes, then reinstall Norton AntiVirus.
Apr 22, 2009 | Microsoft Windows Vista Home Premium...
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
Missing MSIEXEC.EXE
Try this:
To unregister and re-register Windows Installer:
Click Start, and then click Run.
Type in the Open box: msiexec /unregister and then click OK.
Type in the Open box: msiexec /regserver click OK.
Feb 17, 2008 | Microsoft Windows XP Professional
Uninstall nero problem
Better way is to remove it through regcleaner.......
Dec 27, 2007 | FBM Software ZeroSpyware 2004 for PC
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
