Question about Cyberhome DVR 1600 DVD Recorder
No Disc The unit is not recognizing the disc. When I put any disc in it reads "no disc" I have the correct blanks in and have tried ones that are already recorded and it doesn't read any at all.
  • Anonymous Nov 22, 2008
    When I put a dvd, in the screen appears the icon that represent the dvd is loading for a while, after that I read "no disc"
    Problem Solver:
  • 12 Answers
I had this identical problem just after a year and a half of use. I tried cleaning the lens... that didn't change anything. I tried using movie discs that I knew had worked before.... same problem. I took the unit apart and found the problem. There 5 or 6 (I forgot exactly) capacitors on the power board that are black cylinder types with silver tops. If the tops look like they are bulging, then It requires changing capacitors on the power board. I ordered them through the internet, removed the old and installed the new capacitors. Now everything works great.
The capacitors are: 10v 2200uf 105-Degree Capacitors. They cost about 20 cents a piece.
Good luck.
Posted on Nov 25, 2008
  • 128 Answers
Try to clean the lens by inserting a cd/dvd lens cleaner
Posted on Nov 12, 2008
My burner don't recognize the blank disc
Good day,
One of the reasons why a CD drive won't recognise a disc is if d disc is corrupt or not good again. I'll suggest that you buy another one and see if the cd drive will see it. If not, try putting a non-empty disc (either a movie disc) and see if it works. If it doesn't, then d burner might have a little problem.
But if it does work, please feel free to reply.
Thank you for using Fixya!
Aug 21, 2012 | Toshiba Satellite A215-S5837 Notebook
I think you just answered your own question... Did you say that when i you put in a blank disc, it says blank disc? Thats correct. And whats is a B-Deck?
Oct 06, 2008 | Sony RCD-W500C 5-Disc CD Recorder
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
After copying the dvd video content, and inserting the blank disc, Roxio does not recognize the blank disc and continues to say 'please insert blank disc' I have tried both DVD R and DVD WR. Please help!
If your roxio software does not read or recognize the disc that you are using, you can use other brands of disc to check if the disc that you are using is not compatible with the software.
Cheers . . .
Mar 08, 2011 | Roxio Easy CD & DVD Creator 6...
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
Won't record on blank disc.
Bulk disc that comes in cylinder case are some time faulty and loses quality because they packed on each other. The lens of the disc are sensitive so if disc is scratch or dirty will get error message "no read". Turn the unit off then unplug ac power cord for more than two minutes then reconnect and try disc again, if issue still exist purchase disc that comes in individual case.
Sep 15, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Dvd won't play disc
hi. the actual lens assembly has become unstable and this is misaligned the lens. it is unable to line up correctly with the inserted disk so that it may recognize and read the data. when this occurs, the default reading will be WRONG DISK.
You with have to replace the entire lens assembly, which is one whole piece, to actually restore this unit to its original state.
Please rate and god less:)
May 13, 2009 | RCA Televison & Video
My Philips DVD8421 burner will not recognize a blank DRD-R disc.
Ok, the reason is quite simple. The Philips DVD8421 does not recognise the DVD-R format.Not all DVD/CD burners read all discs. It does recognise DVD+R though. So all you need to do is use these discs instead. This should solve your problem.
Hope that helps.
Dec 05, 2008 | Philips (JR24CDRW99) CD-RW/DVD-ROM (Combo)...
Can anybody help me, I purchased a Samsung dvd recorder model dvdvr350m, since purchasing the unit it will not recognize that it has recordable dvd's in it (dvd-rw),it tells me no disc inserted please...
Did the sales guy use the same DVD-RW that you did? Maybe the brand you are using is not of good quality and can not be recognized by the recorder. If he did not use the same disc did you notice if he used DVD-RW or DVD+RW? Some DVD-Recorders only recognize one or the other but this is kind of rare these days. I recommend verbatim brand discs. They should be available for sale at any shop. If you want the ultimate in quality DVDs then go with Taiyo Yuden. This Japanese brand invented recordable media and in addition to that they are obsessed with quality. is always where I get my discs.
Thanks for reading!
Hope this was helpful
Apr 30, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Cyberhome DVR 1600 DVD Recorder Logo
179 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
