Question about Acer Aspire 5315 Notebook
Wirless not working
I had to completely restore my laptop and ever since i rebooted it i cannot connect to the internet via the wireless button, It flashes that it is enabled but i keep getting the message internet disconnected. I have the virgin wirless set up in my house and i have tried to contact both Acer and also Virgin and no-one can help.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
did you try to re-install
the driver of your wifi?
Posted on Nov 12, 2008
Cannot get an HP G60 120US running Win Vista SP2 to recognize wireless internet connection. Wireless button will not turn blue (on), even after a two-minute power down reset with the battery removed...
I've had similar problems with wireless cards refusing to turn their light blue until the driver was updated via windows update. Obviously I had to do this using a wired connection. Try connectiing with a wired connection and udating until windows update tell you everything is up to date then restart your laptop and wait for about 5 minutes before you press the on/off button on your wireless. You can also try removing the wireless card (physically I mean) rebooting, shutting down and replacing the card then rebooting again. If you know anybody that has the same kind of laptop ask if you can try their wireless card to see if it's a fault with that. Sorry I can't help more.
Jan 15, 2011 | HP G60-120US Laptop
Wireless internet is not connecting
dear,
Pl check with your modem wirless port is active or not samething in to your laptop and desktop.
after connection pl give your modem ip range and search for wirless device.
Regards,
Ravindra Shah
May 17, 2009 | Microsoft Windows XP Professional
Wireless Internet for compaq Presario
Check out the wireless setup manual for your laptop here:
http://h10032.www1.hp.com/ctg/Manual/c00065819.pdf
Hope this helps!
Mar 28, 2009 | Computers & Internet
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless internet is not working my wirless card does not work
remove network connection for wirless,
remove wireless card,
reboot,
then shut it back down,
while off reinstall wireless card then boot back up,
it should ask you to configure it.
May 02, 2008 | Computers & Internet
No wirless connection icon
This could be complex, but the simplest solution might be to do a system restore back to a date when you knew the computer was working properly. Try that, and let me know if that fixed the problem.
Apr 22, 2008 | Computers & Internet
Cant connect to the internet!!!
well first i can suggest trying to reinstall the drivers for the ethernet controller and the wireless card you are using. if that does not solve the problem, then are you subscribed to internet through cable, which is what your router connects to?
Jan 05, 2008 | Dell Latitude D600 Notebook
Acer Aspire 5315 Notebook Logo
440 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
