Question about Intel DG31PR Motherboard
Problem in installing audio driver of DG31PR with window XP sp-2
I've DG31PR intel motherboard,when i'm install audio driver then it shows succesfully installed but there when we execute movie maker than it shows no mixer installed and if we check sound and audio devices from Control panel than the dialog box shows no devices installed and there is no sound control in system tray.pl provide me the solution I'll be very thankfull to u.
Thanks And Regards
Ankit
  • 6 more comments
  • Anonymous Nov 26, 2008
    i installed asll drivers but in audio it shows failed what can i do can you tell me pls help me
  • Anonymous Dec 12, 2008
    Thanks And Regards
  • biswajit_ccp Dec 13, 2008
    I have installed the audio driver, but it doesnot works it also show the realtek software available but output audio doesnot comes. Plz tell me how i solve this problem
  • dnagesh81 Dec 21, 2008
    problem in installing audio driver of DG31PR with window XP sp-2
  • Anonymous Dec 31, 2008
    I've
  • dnagesh81 Jan 11, 2009
    i am install DG31PR audio drivers it is working but any video or audio player running and close the player and second time open that players they are not working it show error sound drivers not installed then after i am restart my PC ofter working few minutes again same problem please salve this problem
  • prabhu234 Jan 24, 2009
    Thanks And Regards
  • arunck18 Apr 09, 2009
    send sol to arunck18@yahoo.co.uk .
    am using dg31pr board audio driver not working so pls send me a driver software
AUD_allOS_5745_PV_RTL from Intel, and MS Service pacj 3 fixed this problem for me.
Posted on Jan 10, 2009
I've DG31PR intel motherboard,when i'm install audio driver then it shows succesfully installed but, if we check sound and audio devices from Control panel than the dialog box shows no devices installed.
please send me solution of this problem.
thanks
sirajuddin
Posted on Dec 12, 2008
  • 22 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
134
Posted on Mar 13, 2009
Hi, i got this motherboard too. First i install using the drive from the DVD seem same problem. But i try to re-format everything then the first thing i do is go to this webpage to download the latest driver
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2839&DwnldID=16998&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
After download then install it. wa la... it solved.. :-) hope this will help you.
Posted on Nov 14, 2008
  • 33 Answers
Try the latest drivers from http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839 . AC 97 drivers will often install OK but not work unless they are the correct ones.
Posted on Nov 12, 2008
Tengo un prolema con el driver de sonido de una targeta intel Box dg31pr pueden ayudarme con elcontrolador. Y también no me funcionan los puertos USB palacioz@etapaonline.net.ec
Marcelo
Posted on Jan 29, 2009
3 Suggested Answers
  • 942 Answers
SOURCE: soundcard is not working
you can check the BIOS if the audio is enable, first thing to do is, when you turn on the computer you just press successively the delete key your keyboard, after that your are now int the BIOS, use arrow down, up left and right, the chose the perephiral devices check if the audio is enabled, if disabled press enter and chose enable, after that you press F10 to save the changes, then check your audio
Posted on Jun 30, 2009
Geekman
  • 32281 Answers
SOURCE: 've DG31PR intel motherboard,when i'm
Try installing the latest audio driver from the Intel WEB site.
You can download the motherboarddevice drivers from Intel WEB site. Select your model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers that
matches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Posted on May 07, 2011
've DG31PR intel motherboard,when i'm install audio driver then it shows succesfully installed but there when we execute movie maker than it shows no mixer installed and if we check sound and audio...
May 07, 2011 | Intel DG31PR Motherboard
Pci driver is not installing
Intel DG31PR Motherboard has Intel 3 Series Chipset and you have to install the chipset drivers, which would install the PCI Drivers as well. Please visit the link given below, download the chipset drivers and install them.
Intel DG31PR Chipset Drivers
The above drivers support Windows 7, Windows 2000, Windows XP Home Edition, Windows XP Media Center Edition, Windows XP Professional x64 Edition and Windows XP Professional
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Intel DG31PR Motherboard
Hi, I am using DG31PR board, I have a problem with audio driver after re-installing XP operating system. Its not detecting so, please provide me right driver to install it.
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows
Mar 16, 2011 | Intel DG31PR Motherboard
I have Intel DG31PR dual core board all softwares installed correctly in windows XP but audio driver not installed correctly plz help me to solve this problem
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 26, 2010 | Intel DG31PR Motherboard
Intel motherboard DG31PR classic audio driver not installed
You can download the motherboard drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Please click on this link and select your model motherboard : -
Sep 20, 2010 | Intel DG31PR Motherboard
Soundcard is not working
download an install realtak from this link
Realtak
http://www.filehippo.com/download/file/6d9617675372e9b5725cb0dc31138abadf82844b2cd66b2e02a5556c8f056b85/
Jun 23, 2009 | Intel DG31PR Motherboard
Dg31pr audio issue
You need to Uninstall sound drivers then download microsoft UAA drivers for your O/S and install them then reboot
When restarted install sound drivers through device drivers
When it works give me a fixya please
Nov 14, 2008 | Intel DG31PR Motherboard
Audio device not working in INTEL DG31PR board
2)Right Click My computer
3)Click properties
4)Select Hardware Tab
5)Click Device Manager
6)Click on the cross of System Devices
7)Right Click Microsoft UAA Bus driver for high definition Audio
8)Uninstall this (this is the problem making place and this might indicated as yellow color explanation mark before you uninstall it)Just uninstall it
9)Now install your newly downloaded drivers which i have asked you to download in the previous post.
10)System will ask to restart momentarily just follow the instructions and reassert .
Once all the installation and restarting are done your Audio will work with out any issues
Hope this will work and please let me know if my post able to fix ur problem.
Jul 28, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
4,653 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
