Manual required Can I download or purchase an instruction manual for an ELECTRO POND HEATER 3kw for koi pond -240v - 13 amp - 900 series
  • jmye703 Nov 16, 2008
    downloaded manual for pond heater
Went on website for makers of this product and obtained instruction manual
Posted on Nov 13, 2008
Howmuch aquaremdoi put in my pond
What size is your pond Length X Width X Depth. What temperature is your pond at? Is the pond located inside or outside? How big are the Koi? and how many are there?
Jun 04, 2014 | Tetra Aquarem Pond Water Clarifier / Size...
How do i get rid of frogs from my koi pond
Empty the pond for a week, keep the KOI n an alternative location.
The frogs will move on for the most part.
Second add a filter and a pump to the pond, this will eliminate and Mosquitoes and other such food source from there Appeal to the pond
Third, any tall grass should also be removed.
If you can't move the fish for a week, try fencing with a mesh netting around the pond, but make sure it is dug into the ground and at least 2 feet high, 3 would be better.
Also Snake repellant keep frogs at bay as well, but keep it far away from the Koi!!!
May 27, 2014 | Hunting
How often can I add pond clarifier to the water
I found an answer on another pond company blog. They recommend once a week for pond clarifier and the same for the algaecide
Jul 26, 2012 | Beckett Water Gardening Beckett Corp 16 -...
What size hole need to be dug to fit the liner?
The Koolatron Koolscapes 84 Gallon Pond Kit contains a 6x6 foot liner. The actual dimensions of the pond could be varied but you will want a 6-10 inch overlap on the bank. Basically depth x2 + width = 5ft. 2-6in. So approximately 1ft deep by 3ft. across. If you are planning on keeping koi 2ft. deep is the bare minimum 3ft. if you have freezing conditions so I wouldn't recommend it with a pond of this size.
Mar 31, 2011 | Koolatron Koolscapes 84 Gallon Pond Kit
We have a Beckett Pond Heater and when we placed it in the pond this year it went to the bottom and will not float. It seems to heat, but we are expecting thick ice. Any suggestions?
The purpose of the heater is maintain an open water space on the surface for gases to exchange into the water. Whatever was in place to keep this unit afloat must be replaced (ie Styrofoam). Or, if the the unit has an air chamber to keep it afloat perhaps the element burned through it and it's filling with water.....try to plug it with some epoxy glue.
Nov 15, 2010 | Beckett Corporation Beckett 7137010 Rock...
Servicing a koi pond filter - Hoselock Bioforce
You can backflush it. Just swap the intake hose over to the outlet hose, then put the outlet hose on the intake. Don't forget to remove the outlet hose from the pond. Run the pump for a minute or so. Then switch the hoses back.
If it's real dirty, turn the pump off and take the outlet hose out of the pond, then undo the clips on top of the filter and lift of the top, then clean the sponges. Re-assemble.
Feb 20, 2009 | Garden
PUMP RUNS BUT DOES NOT **** UP WATER
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Jan 09, 2009 | Little Giant Opwg 71 71 Gpm Out of Pond...
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
