Epson 4800 pro stylus has blocked nozzles that will not clear with power cleaning Photo Cyan and Photo Magenta have clogged nozzles and several power cleanings have not helped.
  • 19,396 Answers
Do a couple of times nozzle cleanup procedure first.
Posted on Nov 12, 2008
  • Ginko
    Ginko Nov 12, 2008
    Do nozzle cleanup procedure again first. I know it did not help , but this is the procedure.
    You also need to test new cartridges for the clogged head color, I know they are expensive, but this must be done.
    When The nozzle cleaniup does not help, it is usually necessary replacing , or removing and cleaning the printer heads.
    Before removing the print head you can try an old trick, that consist in printing at least 100 pages of the same document with only one text line per page, written in the faulty nozzle color.
    In your case you hould o it twice. For the magenta, for example, you write a document in word, with one line of "xxxxxxxx" in magenta color.
    And print 100 of them.
    Sometimes this trick works.
    If that does not work, after testing different cartridges, you will need to remove the ink carriage, by unlocking the lever aside the carriage, and leave it overnight in isopropyl alcohol or cleaning solution.
    An alternative is using a printer cleaning cartridge filled with cleaning solution.
  • Ginko
    Ginko Nov 12, 2008
    You need to try new inks first, see this testimonial: Sharing Experience: Epson 4800 printer nozzle clogging and ...
    Here you find the cleaning cartridges:
    Lyson original (best but expensive):EPSON 4800 or Lyson | Cleaning Cartridge Set for the Epson 4800 | E48CF.SET
    Ebay: Epson Cleaning Cartridges C68,88,CX3800,4800,5800,7800 - eBay
    Before
    In your case
    If
Problem printing yellow.
IIf the cartridges is original epson there is some color (light magenta that is clogged.
if the cartridges is non original check that is with the right order
Apr 23, 2015 | Epson Stylus Photo R300 InkJet Printer
Clogged print head
Put the black ink cartrige nozzle in warm water and wait several minutes.I don't know if this will work in your case but you should try it. I had similar situation and this helped.
Dec 15, 2011 | Epson Stylus Pro 4800 InkJet Printer
When printing a red line appears about every 8mm through the all of the page i am useing a epson rx630 fred
It means some nozzle not perfect. If you check nozzle, there is missing lines for some nozzle. Example : Print blue color ( 100% cyan + 100% magenta). If some point of cyan head is clog, the output will be shown that at some lines just show magenta. It repeated. Yous said every 8 mm, so, you must print it at best photo quality. If you have print at best photo quality, and lines still appear, it must some nozlle badly clog. Try do head cleaning, wait for 30 minutes. Check Nozzle.
Jun 25, 2009 | Epson Office Equipment & Supplies
I have an Epson 4000 which has a clogged nozzle
I have an Epson 4000 which I started using new in Sept 2004 and my magenta is clogged too. I've gone through 2 maintenance tanks trying to clear it, (and LOTS of ink), but the magenta is still blocked. I even tried this: http://www.youtube.com/watch?v=3NR8g4qUAJc trick but it didn't seem to work. I hope you have better luck.
Feb 23, 2009 | Epson Stylus Pro 4000-PS InkJet Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Print problem with Cyan cartridge
i had to run 10 cleaning to get a printer to print magenta. finally it cleaned it self..it gets expensive..leaving your printer on keeps the in nozzles clean..when its off for long periods it dries in the nozzles.
Oct 14, 2007 | Epson Stylus Photo R320 InkJet Printer
62 people viewed this question
k24674
jasbo
jasbo
