Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile side-by-side GSS23GSB SS constantly BUZZING
My GE Profile side-by-side refrigerator (model # GSS23GSB SS) which came with our new build house in late 2005, is making a continual loud buzzing noise. It appears to be coming from the freezer side. I noticed this last night and found the ice bin overflowing and the water guide which is used to direct the water into the ice tray had been dislodged. I dumped the ice and put the guide back in place. The noise stopped. I woke up this morning and it is doing it again. It does seem like it is related to the ice maker but I am not sure. Any suggestions? Thanks!!
  • Anonymous Nov 15, 2008
    There is a loud noise coming from the freezer. I checked the ice tray and it is full. The noise stops as soon as the doors are open. I beleive the noise is coming from the ice maker. Any suggestions.
5 Suggested Answers
  • 35 Answers
SOURCE: GE profile side by side refrigerator
Replace Evaporator motor .
Posted on Dec 09, 2007
  • 1462 Answers
SOURCE: ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Posted on Aug 23, 2008
  • 1619 Answers
SOURCE: There is a buzzing when the compressor starts
Sound like the freon charge is low, have it serviced and check for leaks. Might be time for a new fridge.
Posted on Jul 31, 2009
  • 1218 Answers
SOURCE: The ice cube tray in the automatic ice maker
Good day,
Sounds like a bad water valve located in the rear bottom of the machine. (not shutting down properly).
Solution is to replace the valve.
In extremely rare cases it can be a faulty ice maker.
The ice maker sends power to the water valve for 7 seconds on each cycle. If the circuit board in the ice maker malfunctions, it could cause this problem.
But again, very rare.
Posted on Dec 04, 2009
Testimonial: "I replaced the water valve, and the over fill problem did not go away. I guess my next step is to replace the ice maker itself."
Freezer side constant 40 degrees.refreg.side 60 degrees. frost build up in freezer side in back of freezer. this problem has been constant for more than 24 hours. tom murray
om I know that refrigerator and if you will follow these simple instructions we will get you solved.On the PSS26MSrss Profile/Artica. you hardly have a defrost time issue when you seee frost on the rear panel. Unplug and make sure the model number is what is listed here and I will tell you how to fix it. OK?, Sea Breeze
Jan 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ge profile built in SS refrigerator
Go to www.geappliances.com - service and support section - parts and search for your model number . You will be able to get an exploded diagram in pdf format for each section of the appliance.
Graham
Nov 21, 2008 | GE Profile¿ 48" Built-In Stainless...
Profile side by side refrigerator,model #GSC23LSRC SS
Have you tried a new GE filter? Use only GE brand. You can purchase a bypass plug from GE parts 800-626-2002
Jun 23, 2008 | GE DBSR453EBWW Electric Dryer
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
101 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
