Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
Brother MFC 215C :yellow and red refuse to print
All cartridges are 75% full; the ink levels show ( on the PC) blue nearly empty with the others nearly full. The printer gives a message " blue ink nearly empty". The test impression only prints the black and the blue.
When trying to print an image, it effectively only prints these 2 colours.
Have run the cleaning heads procedures about ten times, without results.
Any help ?
If nothing can be done, can anyone reccommend a good printer serviceable by myself where i won't run in the same problems ?
  • 1 more comment
  • Anonymous Jan 15, 2009
    Por favor, describa los detalles de su problema a continuación. We'll add Vamos a añadir
    your post as a comment to milan11's Brother MFC 215C :yellow and red refuse to print problem, and notify you when a new solution is offered. su puesto como un comentario al milan11 del Brother MFC 215C: amarillo y rojo se niegan a imprimir problema, y que le notifique cuando una nueva solución se ofrece.
  • bvbeers Feb 07, 2009
    I have the same problem, also with yellow and red.
  • Anonymous Mar 25, 2009
    I have the same problem with yellow. I changed the cartridge but still nothing. The test print is completely blank for the yellow which suggests that it isn't a head problem that cleaning would solve.
    Sergeant:
  • 420 Answers
Slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Posted on Sep 15, 2010
I have a Brother MFC-215C.The yellow isnt working.Iwas adviced to clean the print head as recomended by Brother.Idoes it 5 times with no results.please help me.Ilike my printer and dont want to change him.
Replace the yellow ink cartridge and try again. If it's the same then the printing head is clogged. To clean it you must remove it from the printer. For that look at this - it has the same mechanism
Sep 27, 2011 | Brother MFC-215C All-In-One InkJet Printer
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
My Brother MFC-215C printer Won't print
1. check to see if you have removed the protective tape that covers the contacts.
2. check to see if you have inadvertently put the cartridges in the wrong sockets.
Apr 22, 2010 | Office Equipment & Supplies
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
MFC-215C printer not printing
Hi, I had the same problem and found the answer from one website. Heres how you can fix it
1) Open the cover
2) Remove the empty cartridge
3) Close the cover without putting in the new cartridge
4) Open the cover and install the new cartridge
5) Close the cover and restart the printer (press power save to shut down and press it again to turn it on
It should go into cleaning and when you check the Ink Status monitor, it will detect that the ink is full.:) Hope this helps, it worked for me
Apr 02, 2008 | Brother Multi-Function Center® MFC-215C...
Mfc 215c printer ink problem
yes. unplug machine from power outlet. take all carts out. wait 5 min. leave scanner top open when powering up again. machine demands carts. reinstall carts and ANSWER display.
DO run a firmware update afterwards (see brother homepage of your country).
Mar 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-420CN All-In-One
unplug maqchine from power. take all carts out. wait 5 minutes. connect machine to power. insert carts as demanded. give the right answer if machine asks if the carts are changed. machine will do some cleaning.
do you use generic ink? in that case you might have clogged the printhead with wrong ink. The ph cant be cleaned anymore.
nevertheless try this (carts should be nearly full!):
press menue then start mono (blue copy) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4. Machine will display init_all. press start mono. machine will refill tubes and
ph with fresh ink and do some cleaning. after that press 7 then 6 then 3 and start mono. machine will do a powerpurge.
press zero then 9 to do a quality test print. If it cant do the job leave maintenance by pressing 9 then 9. do the test print manually by pressing ink etc.
If you still do not see any colors the ph is clogged and cant be fixed anymore. It has to be replaced.
Dec 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother ink monitor not working
There could be a posibility that you may be low on ink. The reason i say this is that you say it prints green. Green is blue and yellow. That means that your red is empty or dried out. If you are low on ink you will have a low or no ink indication and sometimes the software for the printer only has 3-5 diffrent indications.What i mean is when you see the data for your ink there are diffrent levels that it shows. Your software may not be able to diffrenciate between the colors just the status of say one color in your case it could be red.Therefore it would read 0% of ink avaliable but still be able print green. If i were you I would buy a new ink cartridge and see if you get the same results.
Sep 19, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
451 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
