Question about Lexmark P4350 All-In-One InkJet Printer
Printer feeding paper uneven and jamming
Using plain paper, as it starts to feed it draws down from the right side and then jams. Tried just using one paper at a time and still jams. This Lexmark's P4350 is only 2 weeks new. Any ideas or should I return it?
  • 1 more comment
  • shenfan Nov 12, 2007
    I have the same problem. I bought this Lexmark P4350 All-In-One InkJet Printer at Wallyworld for a decent price but the feeder is gone. I guess that I'll have to buy a new printer.
  • Anonymous Mar 13, 2014
    My printer kept jamming to one side, so as suggested, I cleaned what I could reach with a cotton swab and alcohol, then turned upside down and shook. Found a piece of a lady bug. I was then able to print about ten pages, then the problem started again. I repeated the process, but with no luck. When I turned the printer back on it displayed paper jam, so I shook again. Nothing. Now when you plug it back in, it comes on, acts like it is trying to feed, and then shuts off. It does this repeatedly.
  • Anonymous Mar 23, 2014
    tractor feed grabs paper unevenly, starts to print then jams
To be honest mate I am quite gutted myself before I purchased the p4350 I had an x1130, similar printer ie, all in one which lasted for about 3/4 years..but it recently stopped feeding paper. ie.. feeds it in on the right hand side and then gets stuck.. same problem. so I decided to replace it and purchased the p4350.. as i thought the problem was a one off!! But oh no.. i AM VERY SURPRISED THAT AFTER ABOUT A MONTH this printer has done the same thing!! I am hapy yours is too as i know it is not something I am doing wrong!! I can't personally find a solution to the problem. luckily I can replace it easy enough because I got a replacement cover out on it... BUT I won't be changing it for another lexmark! and I am just going to email Lexmark now as their paper feeding mechanism seems very poor as many other people are experiencing the same problems with different Lexmark printers!!
Posted on Jan 24, 2007
My proposed solution was given to me by a Lexmark Tech. It applies to 4350 and 4850.
1. Under the Control Panel, choose Add Remove Program
2. Repair Microsoft Framework 2.0
3. Load MSCONFIG
4. Choose Selective Startup -- you will need to restart the computer
5. Uncheck Loadup Start Items -- too allow the complete program to load
6. Uninstall Lexmark
7. Reboot
8. Install Lexmark files from support.lexmark.com
Posted on Dec 18, 2007
I have the same problem, and the printer was just 2 weeks outside of it's warranty. Then it progressed to saying there was a paper jam (there isn't). I have followed all the suggestions theat lexmark emailed me and nothing works... Gutted. Will have to buy a new printer now!!!
Posted on Dec 09, 2007
There is no other solution other than to get a replacement. i have had three p4350's since February 22nd 2007 to June 2007. they are conning people into buying substandard equipment. they also do not guarantee their work/replacement. the warranty originally 1 year is eroded each time you get a replacement ie as from the day you first purchased it. so believe me when the day my statutory rights come into play i will give lexmark a rougher ride as possible, after which will never buy another lexmark. tom carroll, sunderland
Posted on Jul 05, 2007
Paper feeds crooked then jams?Used less paper different paper it just pulls the paper in unevenly the jams. Help
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Apr 09, 2010 | Epson Stylus CX9400 Photo Printer
Uneven paper feed
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 02, 2009 | Office Equipment & Supplies
Paper jams on right side when facing the printer
Please follow these steps :
May 01, 2009 | Office Equipment & Supplies
Paper jam on Lexmark X2500. Have tried numerous solutions
Please try this step if it still fails then its the problem with hardware of printer,
Apr 20, 2009 | Lexmark X2500 All-In-One Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2250 uneven paper feed
Oct 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper jam...
Aug 18, 2008 | Lexmark X2350 All-In-One InkJet Printer
Cannon Pixma 450 Paper jam
May 27, 2008 | Canon Pixma MP450 All-In-One InkJet...
Paper Jam issue
Mar 06, 2008 | Lexmark X2500 All-In-One Printer
Lexmark P4350 All-In-One InkJet Printer Logo
373 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
