Can I replace battery?
Black and Decker Auto Pivot Vac #PAV1200W is only for vehicles as this operates off your battery via cig lighter. You have to remove the cig lighter. Also, it will not use A/C outlet even if you have cig socket version in A/C outlet. Did not even vac or have power. I thought that I could use it for inside house and in cars, but it's only for cars. Haven't tried it in my car yet. Thought this would of been good for deep down in couches and stairs, but I guess not. Just saying. It's now off the market I see.
SOURCE: Black & Decker hand held dustbuster
First make sure it's not the wall charger - use a meter or a flashlight bulb to test the 15 or so volts that should be on the contacts when the charger is plugged in but the unit is detached.
The next thing is to remove the filters and see how easily the "fan" spins - use a popsickle stick or something that won't break the plastic fan if you can't get your fingers on it. Tight bearings may indicate clogged with dust (or corrosion) or destroyed. Free bearings likely indicate a switch or battery problem (good motor.)
SOURCE: Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
SOURCE: no problem - received a Black and Decker pivot and need to regist
Simply go to www.blackanddecker.com and register to register your Black and Decker product.
SOURCE: How do I replace the
You can read, download, and/or print the manual from the following site. Instructions for changing the battery are on page 2.
http://dl.owneriq.net/7/7770b6e6-3d24-411a-aefc-2a5e3fe68599.pdf
SOURCE: I have lost the manual
First of all, here is the main Black And Decker ONLINE SUPPORT page for your model:
http://servicenet.blackanddecker.com/Products/Detail/CHV1408
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
To download a copy of the OWNER'S MANUAL for that model, just look under the DOWNLOADS heading when you get to the support page and click on the red and white icon beside INSTRUCTION MANUAL (Print Doc).
After you click on that icon, it will ask you if you want to open or save the file.
Choose SAVE.
Now Choose a location on your computer where you would like to save the file.
The easiest place is just right on your DESKTOP so it will be easy to find later.
Then click SAVE.
Once the download completes in about 5 seconds,
Click on the OPEN button.
If the document opens then just read it, or print it off if you want, or just leave it on your computer to reference when you need it later.
If the document does not open, then you may need a PDF viewer program like ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there and then follow the onscreen instructions to install it.
Install the ADOBE READER program then you can come back to your desktop and open the USER'S MANUAL document and view it without a problem.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
