Furnace Blower stops working after 15 minutes
We have a WeatherKing GU-80G-D3 unit. When the unit turns on, everything works fine for about 15 minutes and then the airflow stops throughout the house. This is true for A/C and for heating. Started doing this in September with A/C and we haven't needed heat until recently.
When the unit does start up, I can hear a humming that lasts a long time before the air starts blowing. It sounds like the blower fan is having a hard time getting started. I am assuming our blower fan is having a problem but wondering if replacement is necessary or taking the blower out and cleaning it would solve.
Any help would be appreciated.
  • ahamil Nov 12, 2008
    the blower stops after a 5 min &hums
  • billy751 Nov 13, 2008
    Thank you.
  • 828 Answers
Replace the blower motor. Cleaning of the blower and motor will help in the moving of more air but will NOT eliminate the real problem in the motor bearings. Over time the lubrication will dry out and bearing wear results.
Posted on Nov 13, 2008
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
Weatherking Furnace will now turn on. Can get blower to work
Does your outside unit run. Does the inside unt try to run. If not you may have control problem. Check voltage on transformer. It should be 24 volts. Rus
Mar 20, 2010 | Weather King 10AJA3601AH Air Conditioner
Weatherking furnace is starting and stopping
This just sounds like a couple of problems. First, your blower is designed to only turn on once the heat exchanger heats up, so the flame will be on for a minute or two before the blower starts. it sounds like your blower is cooling down the heat exchanger too fast and causing it to shut off so it can warm up again...check blower speed for heat, it should be the lowest speed (black wire). Blue=medium speed, red= high speed. second problem could be your flame sensor rod is calcified, you just need to locate this and clean it off with some fine sand paper.it is located in the flames near the burners. Also change your filters, for proper air flow through your heat exchanger.
Oct 28, 2009 | Heating & Cooling
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
WeatherKing Acclaim II
  1. The sensor that tells the furnace whether the gas is lit has got build-up on it and is giving the furnace bad information.
  2. The flame sensor is often a single wire or rod that sticks up in the center of the flame.
  3. You can shut off the furnace and the gas and clean the sensor with some sandpaper.
If that still doesn't work, the sensor may need to be replaced.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
My furnace works intermittently.
You may have a dirty flame sensor. There are a number of other possible causes as well. Rheem/Ruud/Weatherking furnaces also have problems with the connection on the blower deck.
The flame sensor sometimes must be bypassed around the MOLEX CONNECTOR in the deck due to humidity.
Hope this helps.
Matt
maxhtcl1@verizon.net
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Furnace stopped working.
HI!!! Looks like your ignitor has stop working..change your glow ignitor and you should be fine..Good luck..
Jan 04, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
245 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
