Question about Riso RZ220 Duplicator
HELP ME PLEASE
I HAVE PROBLEM WITH MY DIGITAL COPIER...
THE MACHINE IS IR 5000
ITS HAVE ERROR CODE...
E 000350_0003
UNTIL NOW MY COPIER CAN'T USE...
SO...PLEASE HELP ME
ONE AGAIN...
E 000220_0002 IR 600
A-06 -403
Posted on Nov 18, 2009
E000007-0000
This is not a problem for the IR-5000 copier. This is an error code for the instant on copier that use a fixing film assembly. This is error indicating that the fixing film isn't turning in the fuser assembly and most likely is damaged and the fixing film assembly will have to be replaced.
Aug 15, 2012 | Canon imageRUNNER 5000 Copier
I have problem canon ir 5000 e355,,....please help me
How to clear the error code:
1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
3. Under the [FUNCTION] tab, select the [CLEAR] option.
4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
5. Reboot the machine.
If the error occurs again:
1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
2. Reseat the Main-Controller board into its slot.
3. Go into service mode and clear the error code as explained above.
* If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
Aug 27, 2010 | Canon imageRUNNER 5000 Copier
Error Message E000001-0000
its a fuser error high temp or lower temp
try to rest this error in *28* FUNCTION,CLEAR,ERROR then on off the machine
if the error the same try to replace tem sensor
Oct 28, 2009 | Canon imageRUNNER 5000 Copier
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
Help me.....faster....
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Dec 15, 2008 | Canon imageRUNNER 5000 Copier
Help me quickly
Scanner home position sensor,faulty scanner error .Switch machine on/off if the error still show you will need a qualified tech to atted to your machine.
Nov 02, 2008 | Riso RZ220 Duplicator
104 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
