Question about EuroCave Performance 283 Wine Cellar
Euro cave 283 1 temp
Humidity level display is not working. Any advice on this issue
  • Anonymous Apr 14, 2008
    Euro Cave Compact V-056..not refrigerating. Lights are on, indicting that the motor is engaged, but not keeping cold
  • Anonymous Aug 29, 2008
    The temp and humidity digital display are blank. They faded to
    blank over time. Unit works fine but displays are blank.
  • 237 Answers
Likely the humidity sensor has gone bad if display is wrong or the display board itself is bad if no display at all.
Posted on Dec 23, 2006
  • ranchuk Mar 21, 2011
    If the unit is working fine, but the displays go blank, replace the little watch batteries in the back of each display (see other posts on this subject). The batteries only last 4-5 years tops. Eurocave will gladly sell you their "Eurocave LCD Display Replacement Battery" for $14.95 shipping, but if you can buy the exact same Duracell battery for only a couple bucks each at the corner store. Cheers!
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt impact...is this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
Jun 25, 2015 | Dehumidifiers
I cant change humidity levels
Hi Ra Ma,
After you have set the desired humidity, the readout will display the actual room humidity. It has a built in hygrometer which will be on the display while it is running.
You change it and it shows the actual levels.
See page 5 on manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Mar 02, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
My Danby DDR583R dehumidifier no longer dehumidifies unless I set the humidistat to the lowest, constant run setting--then the compressor kicks on. The humidity reading says 14% which I know to be...
There are a several things that can mimic a faulty humidity sensor.
1. The air intake filter is clogged and needs to be removed and cleaned.
2. The coiling coils need to be cleaned.
3. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If the above fails to help solve the problem, replacing the Humidity Sensor is certainly an option. But, before you jump into it, make sure you have an accurate wiring diagram, so you know which sensor is which. As the part does not come with installation instructions.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Danby DDR583R Dehumidifier
What is the proper setting for the Temp &Humidity?
Set the temp level at whatever point your home's temperature is now. Lower the humidity level to 35%. If you don't have an LED screen on your unit, set the manual control to maximum.This way, you will extract the maximum amount of humidity and make your home more comfortable.
Hope this helped you. Please let me know. Thanks.
Jun 29, 2011 | Fedders A7DH45B2A Dehumidifier
Is this a low temp model, as it is not dehimidifiying but fan is running
The model you have was made by Fedders for Maytag. The fan runs as a recirculating fan, to continually sense when the humidity level rises, above what have the unit set on. Here in, may be the problem. If you have the humidity level set higher than 50%, that's pretty high and the unit want remove much if anything. It will just continue to maintain that level. Keep in mind, the unit's humidity level must be set LOW, for the compressor to kick on and start removing humidity. By low, I mean 35% or minimum, if your unit does not have an LCD display.
I must caution you, that there is associate on this website that would tell you, that the level should be set on Maximum. Believe me, that simply is not the case. That is, unless you want your home to be hot and humid.
Hope this helps you to troubleshoot and solve the problem.
May 24, 2011 | Maytag M7DH45B2A Dehumidifier
We purchased 3 Mr. Slim units for an open 1150sq ft. subterranean level classroom with one side walkway. one unit is attached to one condenser and two share another. All three units are set to the...
first make sure a proper manual j is done on the space, then make sure your not bringing in fresh air while dehumidifying. Your either grossly over sized or slight under, you'll know if its over it will feel clammy, you can have mold issues and the equipment will most likely short cycle. If its under sized it will stubble to meet tempetures
Oct 01, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Temp
My guess is that you are trying to bring the humidity up too high. There is a chart in the manual that suggests where to set the humidity at based on outdoor temps.
I try to keep the level at 30-35% in the winter.
Hope this helps.
Dec 02, 2007 | Kenmore 14410 Humidifier
Temp and humidity levels are not correct
It sounds as if the temperature sensor probe is touching the cold coil inside. The sensor is located in the incoming airflow, in front of the cold coil. It must not touch the coil. This should be visible with the cover off. You can gently bent the sensor away fron the coil, 1/4-1/2" of clearance is plenty.
Jun 06, 2007 | Maytag M7DH45B2A Dehumidifier
EuroCave Performance 283 Wine Cellar Logo
753 people viewed this question
Top EuroCave Refrigerators Experts
Marvin
Marvin
 steve
steve
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
