Question about SanDisk Sansa e250 MP3 Player
My MP3 wont turn on or off
I turned it on and it just shows a black screen and the volume cirlce stays lit up the whole time. It wont turn off either!!! What do i do????????????/
  • Anonymous Nov 22, 2007
    I put some firmware on it and now the screen is black and won't go to recovery mode! HELP!!!!
    it wont turn on. It says on the screen Key LOCKED; System shutdown. The volume cercle stays on
  • 40 Answers
Mine did the same thing too. when you plug it into a computer that is running on a flash drive, or you use it nonstop, it wil do this. try resetting the unit. press down on the power/menu button for 15 seconds, and when the pinwheel turns off, wait ten seconds, the turn it on with the HOLD icon in place, and push and hold the record button while it turns on. this will usually bring you to the recovry mode. then you must plug your sandisk onto you rcomputer, and wait for it to tell you when to unplug it. I f this does not work, go to the store that you got it from, and tell them. They will usually happily replace it, but if they don't, then call sandisk, press four for MP3 SUPPORT, and talk to them about it.
Posted on Dec 08, 2006
  • Maxwell Wild Jan 30, 2007
    I have a sandisk mp3 player, and have had to replace it three times now. It is a wierd mp3 player, but its tottaly awsome to play videos unlike the ipod Nano! I learned on my own, truth be told... Trial and error! lol.
Thanks man!!!!!!!!!!!
Posted on Jul 04, 2007
I'm working on it
Posted on May 31, 2007
Thank you sooooooooooo much
Posted on Apr 23, 2007
Omg that actually worked ty Big time man, BTW how u find that out
Posted on Jan 24, 2007
Thanks!!!!!!! this was very useful for me!
Posted on Jan 19, 2007
    Problem Solver:
  • 5 Answers
Hold down the off button for 15 sec.
Posted on Jan 02, 2007
  • 3 Answers
Take the battery out for a second. It should start up normal Further problems usually mean you should format it through media player or RealPlayer this can be a now and then problem..no permanent fix I know of
Posted on Dec 06, 2006
Hold down the power button for 45 seconds... It will automatically turn off, then it will turn on like normal.
Posted on Nov 23, 2006
Oh wow! thank you so much....my sansa had frozen in the middle of a song....i was going crazy because i jusst got it and its already freezing! i didnt know what to do! THANK YOU SO SO MUCH!!!!
SOURCE:
When i turn my tv on the screen just stays black. You can hear the volume. I just replaced my bulb about a month ago. I took the bulb out again to see if it was blown and it wasnt. Does anyone know wh
send me a email slinteriors@yahoo.com and I will send you the info to retreve the error code to find out why the set is shutting down. Be sure to include the moodle number and symptoms with your email
Feb 10, 2013 | Mitsubishi WD-65C9 65" DLP HDTV
My m3 player froze while charging and now it wont turn on
I held it in the off position while at the same time pressing the menu button....it shut off, then I restarted it. It will repair the media itself.
Jun 26, 2009 | SanDisk Sansa e250 MP3 Player
120GB Zune wont turn on
Please try to hold Back, Center and Left at the same time to restore the zune,
Jun 02, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Battery
hi,
check your battery for:
dry
get the round shape from middle
to heat at charging
take less time to charge full
this symptoms for battrey change or weak.
Jul 30, 2008 | Insignia Pilot MP3 Player
Computer not detecting
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
THEN, do the "Repair" in the Philips Device Manager
Jun 01, 2008 | Philips HDD1630 MP3 Player
Screen stays black after splash screen
ooh you got big problems .. i think do your computer regonize the mp3 player? can you see the partitions on the mp3 player
what os are you using xp,vista,ubuntu,mac,kubuntu.....
i hopes that this is useful
maby you can reinstall the whole mp3 serch on google and you find much information
Jan 20, 2008 | SanDisk Sansa e250 MP3 Player
Blank or black screen
there is a problem with the flex..might be damaged..have it replaced by a cellphone technician
Jan 01, 2008 | Motorola Mobility i880 Cellular Phone
The Screen Stays black and the ring turns blue and thats it
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player 512mb wont open all the way
try re-intsalling the progam disk that came with it, than format the whole mp3 player & it should work
Jan 02, 2007 | SanDisk SDMX1 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
135 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
