Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Setup drivers I need the setup drivers for this card since my own is corrupt and need to install them please am in Ghana
  • 435 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest drivers for Philips SAA7130, please click the following link:
Philips SAA7130 driver Download
After clicking, please select your OS and proceed to download.
Thank you and please rate the solution.
Posted on Nov 12, 2008
My VGA has been corrupted. How can I fix it?
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust ,
If supported you can run a LINUX disk like Ubuntu in live / try mode
If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue ,
but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault
If a likely software issue then uninstall and then reinstall the video card
Consult ASUS or Nvidia support
The procedure is something like this
Onboard video support ?
yes
uninstall the video card driver and any video vendor configuration applets
Uninstall video card in device manager if still present.
Shut down and remove mains power cable
remove the hardware video card ,
(using anti static electricity procedures)
Attach onboard video to display
Power up and enter and configure BIOS setup if required, ie 1st seek onboard video
Bootup to Windows
Install the onboard video device
using Windows plug&play default driver executed during booting
Restart
Confirm working ok
Update the chipset driver (inf) if applicable,
restart
Shutdown
Reinstall the hardware video card
Attach to display
Reconfig BIOS setup if required
Start to install default driver
Install video driver / update from card default using a known good driver whose setup file has been previously downloaded
restart and test
Hope this helps
Dec 06, 2013 | ASUS GeForce Computers & Internet
Scaleo p fitted new graphics card asus geforce 210 wont start up
Hi , i suggest try running the driver setup in "custom mode" checking option : clean install , to remove previous possibly corrupt installed settings
Also access BIOS setup and change "first seek peg" or some such, so BIOS communicates to Windows to first seek video device expansion card rather than onboard
(ps , if changed from onboard to expansion card ensure the onboard control applet for onboard video has been uninstalled via add/remove)
Jan 26, 2013 | ASUS GeForce 210 Silent - 512 MB GDDR3 -...
I am in Indonesia, i can call to Ghana, i can receive sms from Ghana, but why i can not reply sms to Ghana?
To Whom It May Concern,
I am very sorry that you are experiencing this problem. I will do anything i can do to help. First Please make sure that there is a Message Center setup or MMS code.
Thanks,
FixYa Expert
Jul 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
I have a laptop toshiba l500d series. My question is the screen turns green only the black parts all the time. What would be causing this problem. Thanks
Hi, the screen may turn green when the Graphic Driver is corrupted. Please re-install the Graphic Driver in the Computer. The Graphic Driver can be downloaded from the Laptop Manufacturer website. Restart the computer after installing the Graphic Driver. If the issue persists, restart the computer and try pressing F2 Key to enter BIOS (Basic Input Output System) setup, then check if the screen displays green color. If the screen displays green color in BIOS setup then the issue is related to Hardware of either display or graphic card of the Laptop. In this case, please contact the manufacturer of the Laptop to initiate the service under Warranty. If the laptop is not under Warranty then service charges may apply.
Apr 17, 2011 | Computers & Internet
My need hd sound cade
Most likely your drivers could have been corrupted.Try updating the driver for your sound card by
following this link and see if it solves your problem.
http://download.cnet.com/SoundMAX-Integrated-Digital-HD-Audio/3000-2110_4-142989.html
Simple download,the above driver and run the setup file to install it.
Oct 28, 2010 | Toshiba SoundMAX Integrated Digital HD...
My windows media player s not working due to some sound device poblem
If it was working recently and you didn't make any changes or delete any files from the windows folder, the the audio drivers of your sound card might have corrupted or missing, you need to reinstall them. Most audio drivers come with the motherboard cd, so if you still have the cd, please insert it on the cd/dvd drive and run the setup.
If you can't do, please let me know with the details of your computer configuration and operating system installed on it.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Computers & Internet
What happens when it says "No audio output device installed." I have no sound. Please respond
Hello! kindly follow this steps below:
Please find your motherboard or sound card driver then insert it in your disk in the CD/DVD ROM if it is in a disk then run the setup.exe of that driver software then follow certain steps given by the computer installation wizard. Then after you finished the installation restart your computer then if the sound is restored then you have a successful sound card installation. You can do this steps again if you encounter same problem next time. The reason why this you receive this error message cause your sound driver has been corrupt and need to reinstall due to some hardware failure and software failure especially if their are virus and worms enter in your system.
Also try to update and install anti virus and update it in order to proctect and level up your security against virus, worms and hackers.
If you need more assitance please reply to this post.
thank you
Jul 17, 2009 | Microsoft Windows Vista Ultimate Edition
Do not have sound
Also try to update and install anti virus and update it in order to protect and level up your security against virus, worms and hackers.
If you need more assistance please reply to this post.
thank you
Jul 17, 2009 | Microsoft Windows XP Professional
Sir or Madam I did work on a compaq P3 desktop and now the sound is not working after i did install windows OS the sound card in the PC is Creative Sound Bluster I will like to download the drivers from...
do not use the cd for the initial driver install remove them if you already installed them, download the latest driver first to your hard drive from here http://us.creative.com/ Go to support and find the audio card you have. Once you have the updated driver info ready, then go to the device manager and find the creative audio driver, it should have an exclamation point showing that it requres attention. Right click and select update driver, when asked by windows to install it, choose the driver you downloaded from Creative. Also, make sure the default sound card is sound blaster using the control panel, sounds and audio devices, audio tab.
Let me know how it works out for you.
Nov 13, 2008 | Computers & Internet
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
507 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
