Question about Sony Handycam CCD-TRV68 Camcorder
Poor colour contrast and rolling viewfinder image
I have a Sony V6000E Hi8 ( PAL) which was unused for about a year.
When trying to play back tapes the colours were very dark and audio was feint. The viewfinder ( B&W) showed a rapidly rolling picture.
Otherwise the camera has been very reliable.
Headcleaner made no difference.
Any thoughts ?
Thanks,
Gee Kay
  • krooglik Nov 12, 2008
    Hi Dan,
    Thanks for the fast reply and suggestions.
    I like the camera very much and am prepared to spend some money on it so I will take your advice and get a technician to check it out.
    Appreciate your help.. :)
    Cheers,
    Gee Kay
  • 4,234 Answers
Cameras from that period are subject to bad capacitors in the video processing section that MAY be the cause of this. I can not state without reservation that this is the cause without seeing the camera in question and looking at the boards. If caught soon enough, replacing the caps will resolve the problem. If not caught, the caps will leak and can destroy some of the traces on the board which will make the camera unrepairable. Please have this unit checked. The caps are not expensive. The repair cost will be mostly labor as it takes time to replace the caps.
Dan
Posted on Nov 12, 2008
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
Can't see how to play Hi8 tapes on this Sony dcr-trv340e pal camera
It's a Digital Hi8. Your tapes are Analog.
But it should play Analog also.
In the menu play with "PB Mode" settings.
Apr 14, 2009 | Cameras
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Hi8 camera tapes
any brand of hi8 or digital8 camcorder will play back those tapes but sony made a tape deck made to record and play back digital8, hi8, and 8mm tape. you can get here http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
Feb 12, 2008 | Sony Hi8 Hi-8 Tape
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Feb 28, 2007 | Sony CCD-TRV228E Camcorder
Sony Handycam CCD-TRV68 Camcorder Logo
128 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
