My tomtom go live 1000's power light comes on but the screen doesn't
SOURCE: TomTom Home does not recognise device
Have you created a TomTom account? For each device you own it needs its own e mail address which it links to and you need to be logged in when you plug in your Tomtom.
SOURCE: Tomtom not switching on
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
SOURCE: Serial number on memory card of TomTom??
Yes it does. Insert the card into a card reader or if you have access to the unit connect it to your computer. Open my computer and open the drive letter of the device. After you have opened the drive look for a ttgo.bif or ttgo.bak file open the file using notepad and it will tell you the device serial number and device unique id. I will tell you this though if their device is working and is not freezing at start up they are not using your sd card. Each sd card has a unique number and will only work with that device.
Hope this answers your question.
you can take it to fix .http://www.sencart.com/Supply-home-light...
