Question about Zanussi WJS1265W Front Load Washer/Dryer
Put it on the drying program and it finishes after 5 mins
Put the drying program on and it will come up with the time lets say 160 mins but after 5 or 10 mins the timer is back to 0 as if the program has finished but clothes are still wet
    President:
  • 1,462 Answers
I suspect you have a blockage in the dryer duct - take top and rear cabinet off and the dfuct is exposed - it often gets blocked with lint
Posted on Nov 12, 2008
I have a 12 station Orbit Model #57900and I want to water the same stations two to three times a day
Program modes
Program A or 1 is your primary program setting. All Zones will run on this program.
Select program B. Or 2
Set start time for program B usually an hour or two after the LAST zone (12) run time on program A or 1
1. set selected run time for the zones you want to run. 5 min -20 min ( leave the others 00:00 or off)
Select program C or 3
And repeat above.
Keep track of the start times of each program as 12 zones running for 10 min will add up to 120 min or 2 hours total. So if Program A/1 starts at 6am it will finish at 8 am. Set program B/2 start time at 11am. Them select the specific area/zone you want to run again will water the area a second time. Just remember to leave the other areas you don't want to water Set at 00:00 or off. Repeat through all the programs and you off to enjoy your day. Cheers
Jun 06, 2016 | Orbit Hardware & Accessories
Pulsar 150 making different noise at low speed
CHECK GASKET FOR CRACKS/WEAR TAKE ENTIRE EXHAUST OFF SPRAY WITH CARB CLEANER LET SIT FOR 15 MIN FLUSH WITH GARDEN HOUSE TILL JUST SEE PURE WATER LET DRY CLEAN INTAKE FOR EXHUAST WITH CARB CLEANER WAIT 25 MIN START IT UP RUN FOR 5 MIN PUT EXHUAST BACK ON.
Jun 27, 2013 | 2005 Bajaj Pulsar 150
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
Need instructions for pasta and more
by how much water do you mean how much water do you put in the pasta or how much water to boil to cook pasta??
cooking pasta is easy.. if its dry pasta around 8-12 mins or according to package instructions but fresh pasta takes a shorter time at around 2-5 mins :D
hope it helps :D
Mar 04, 2012 | Kitchen Appliances - Others
95 lumina security light flashs and no power
You have a little black chip on your key That microchip is read be the lock cyl and lets the ign swich power up its so no can steal you car by hot wiring it.the dealer can reprogram key but will cost a few bucks a new cyl comes programed 150-175
Some chevys if you leave key on for 15 mins turn off back on 15 mins off back 15
mins will program the thrid time 15 mins is up the will flash norm agian.
if not you can measure resitance on chip on key and link together resitors together and loop around ign cyl and it will start do that a few times all the ones i did where
8ohms
Dec 01, 2011 | 1995 Chevrolet Lumina
I have replaced both the colour and black ink cartridges in my Canon Pixma IP 200 printer, but now it won't print anything. I have tried the computers cleaning programs but that has not worked. Any...
The print head is clogged.Try to unclogging manualy.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0054.
Nov 05, 2009 | Canon PIXMA iP2000 InkJet Printer
I hace gigaware pc cam but it doesnt working on my windows vista lap top.Can you help me
Well the gigaware cameras are not made for vista.. but will work if you just play with it.
I would suggest
unplug camera.
restart PC
after the PC has finished booting and is done loading your personal profile
{some computers take 5 min to finish loading all your setting and starting programs}
so give it a few min
plug in camera and walk away
DO NOT TOUCH YOUR PC
let Vista find the camera on its own... do not force.
It should find it and tell you that it has found it and if it found software for it.
give it 5 min
Hopefully that takes care of your issues..
FYI Not all Vistas can run XP software
only PRO and Ultimate are truly XP compatible
ATCAW Computers
Jun 20, 2009 | Radio Shack VGA PC Camera Webcam
Dishwasher light flashes 7 times
although i dont have a lookup for your particular model number. if you remove the lower access panel you will find techsheet/troubleshooter. in it there will be section on "clen light blinking 7x" foplloe direction to put into test mode to clear the fault. belive its,,, heated dry/ sani rinse / heated dry/sani rinse. pushing htese buttons is what gets into test mode
Dec 11, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Zoom button does not work
Go get some Electronic Contact cleaner and on the Side of the Toggle switch spay a little bit in the front and rear of the switch ,Make sure the Battery is out and spray the rocker up underneath to get to the Tact switch,Rock the rocker back and forth several times to clean the switches,The Contact clear will dry quickly,After dueing this let dry for 5 Min put batt and try it good luck Let me know if this works ttech
Jul 24, 2007 | Sony Handycam CCD-TRV16 Camcorder
Zanussi WJS1265W Front Load Washer/Dryer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
