Question about Britax Teutonia Y2K2 Jogger Stroller
How to lock the roof
My roof's front and back sides are always comming together let me know how to lock the roof to keep it wide open thank you
0 characters
1 Points
Easy folding for Peg Perego Pliko Matic Stroller
I fought with mine stroller at the consignment store and no one else could figure it out. But I loved it and was willing to keep it open to have it. I tried the instruction but couldn't maneuver the three handles at same time so I stood in front of the stroller and tipped it forward. Immediately it began folding when I pulled the black handle buttons (on either side)upwards then the handle on the back. It will collapse and fold up. At the bottom on either side above the wheels are latches to secure to keep the stroller together. Amazing!
on Oct 10, 2010 | Baby Strollers
My bugaboo keeps pulling to one side? What's wrong with it?
First check that the handle extension locks hold properly and the handle is not slipping on on side. A handle lock problem (the part that allows the handle to swing from back to front) should be obvious but check both are locking and have the same amount of play. Finally check all four wheels spin freely and the smaller front set can both rotate freely. Your Bugaboo maintenance kit came with a small can of silicon spray. Use it regularly (once every month or two) to lubricate the handle lock, brake lever and wheels. If you find a specific problem let me know and I'll try to help.
Nov 17, 2010 | Bugaboo Cameleon - Tailored Fabric...
I have bought the jane carrera pro 2nd hand and dont have the instructions, I need to know how to fold it properly and how to recline the back
To fold it; Lock the wheels to stop them flapping by pressing down on the catch at the front of the wheels. Push the canopy forward, kick the middle of the bottom brace upwards, then pull both cuffs at the sides of the handlebar up towards you to release the locking mechanism. Then push the handle bar down and together. It folds down onto the wheels and pulls the wheels together.
To recline the back pull upwards on the handle behind the childs shoulders. Then push the back down.
Feb 17, 2010 | Baby Strollers
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
Zooper Boogie User's Manual
There's a safety lock located on the right side of the frame, about 6-8" down from the handle bar. There are also 2 sliding locks, one located on either side of the stroller, on the underside of the frame. One is located just below the safety lock. First pull up on the safety lock, and while keeping the safety lock open, simultaneously slide the other 2 levers up toward you. The stroller will unlock/open and you will be able to fold it.
Dec 24, 2008 | Zooper Boogie Jogger
Hi, I have a peg perego, single child stroller, standard, Not sure which model. It has just a bar not a tray. Anyway, I CANT figure out how to fold it. Theres a carrying handle on the side so I know it...
Hello, if this is an umbrella type stroller, you first release a catch on both handles to unlock the frame. These catches are located on the front and can be pulled up with your fingers. If you watch, they release the bottoms of each side from the front. You then pull the handle or lever located on the cross bar at the back up toward you. Thus collapses the frame as the wheels come together and the stroller then locks closed in the standing position and can be carried by the handle on the side. Greetings from Oz.
Dec 14, 2008 | Peg Perego Aria MT - Toffee Standard...
Kettler Air Navigator Tricycle
My husband and I just put this trike together and had a similar problem - the front wheel always turned the pedals and we couldn't figure out how to stop this. The manual for the trike is awful and very hard to understand. After spending a LOT of time analyzing the pictures and doing all sorts of weird things to the pedals, I found a posting on a website that said they'd had the same problem, but had removed and re-attached the front wheel and the problem was suddenly fixed. Sounds too good to be true, right? Well, we noticed that in one of the manual's pictures that the air valve for the front tire was facing the other direction - we'd actually put the tire on backwards. I took the tire off, put it back on facing the other way, and suddenly it all works as it's supposed to.
The thing is, you actually don't have to "do" anything to change from free to fixed and keep the pedals stable. If my daughter pushes the pedals around, they move around, and if she keeps her feet steady on them, the wheel continues to go around while the pedals stay put. It truly is automatic, which the diagram in the manual does a terrible job of conveying.
Hope this helps someone. We like this trike, but the directions are beastly!
Aug 18, 2008 | Kettler Kiddi-o Supreme Stroller Trike
OK, after about an hour of messing with the duoglider I bought at the local baby exchange I finally figured out how to open the stroller back up. There is two grooves on the red latch. The groove that looks like your finger fits in is the one your looking for. Stick your finger in the groove and push down. The latch will snap right out. It is decieving because it looks like that red latch is screwed on both sides. I hope this helps. Any problems email me at
Jul 10, 2008 | Graco DuoGlider 7924 Twin Seat Stroller
Graco quatro wheel removal
i have the graco quattro tour sport, i put it together & noticed the swivel lock was missing! I have to take the wheel back tonight but i had already put it on the pram! after reading 'Adorough's' comment i had good look at the wheel to figure out how to get it off. 1) fold the pram up and stand it so the front wheels are up. 2) if you look round the back of the front wheel you should see a round 'pin' which is set back, you well need a pen or something pointy to press the pin in & pull the wheel! That worked for me.
Dec 31, 2007 | Graco Quattro Tour Travel System
Britax Teutonia Y2K2 Jogger Stroller Logo
18 people viewed this question
Top Britax Baby Strollers Experts
Stephen Faulkner
Stephen Faulkner
ray gallant
Tom Chichester
Are you a Britax Baby Stroller Expert? Answer questions, earn points and help others
