Question about AOpen AK77-8XN Motherboard
CPU upgrade problem
I have a Aopen AX77-8XN mobo and I upgraded my cpu from an XP1800 to an X220. Now my computer won't boot past the windows set up screen? I know I have the latest bios... does anybody have any solutions?
Hello Roger, both of my drives are Western Digital. My primary being the 160 GB (which has windows installed on it) and my secondary being the 80GB.
Posted on Nov 13, 2008
Hello Roger, I was running Vista I've done a clean install and gone back to XP (good excuse to finally get it done.
System Specs:
1 gig of ram running at 333mhz
ATI Saphire X1550
Sound Blaster Audigy Platinum
2 Hard drives one is 160 gig the other 80
Lastest Bios
I reset the bios by removing the battery, I also tried shorting the jumper which also didn't work.
When I had vista installed, my computer kept going to the screen where I had the option of choosing safe mode or start windows normally. I also restarted my computer making my DVD drive the first boot device I couldn't get the repair option screen. Once I put my old CPU back in everything worked fine.
With my old CPU in, I formatted my drive... (with my XP disc) once again making the DVD rom the first boot device. Once I got the windows is starting screen, my computer would just freeze.
Once again I installed my old CPU and my computer booted and windows XP wants to install fine.
Can you guys shed any light?
Posted on Nov 12, 2008
    Problem Solver:
  • 18 Answers
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
  • softwaresale Nov 13, 2008
    Hi
    What kind of hard disk is your primary and seconday master or slave. I just want to know which hard disk is the OS installed on because it maybe a failing drive.
    Thanks
    Roger
How do I switch/upgrade my motherboard from a 32bit to a 64bit please
Having a 32-bit or 64-bit operating system mainly depends upon the operating system that is loaded on your primary hard drive (generally drive C:). However, your motherboard's components, i.e., processor and amount of system RAM, will be a major factor in determining whether you can only run a 32-bit operating system, or upgrade to a 64-bit system.
Sep 22, 2014 | Computers & Internet
Upgrade the cpu for a sony vaio vgc-ra834g pc
I have upgraded cpu in the past, its a solution that is limited as you prob cant upgrade it again, newer motherboards support newer cpu, Maybe look for a cpu mobo combo to buy them both, Depends how much you can afford.dont forget if its an older mobo, it prob takes the slower memory, todays is faster. will your old mobo support newer graphics cards if you play games ??
Jan 26, 2013 | Sony VAIO VGC-RA710G PC Desktop
Upgrade for NEC COMPUTERS INTERNATIONAL MS-7168 1.0 mobo
There is no limit to what you can upgrade your CPU too, although your mainboard has socket 939, so your CPU should be the same.
I cannot advise you wether or not it would make your PC faster, for that I need to have more specs and the kind of thing you use th PC for. (video-editing/games/casual)
I hope this helps,
Yannick.
Apr 15, 2009 | Computers & Internet
Motherboard and cpu upgrade
Your hard drives are not setup for that mobo run the windows cd again/safe boot if you can (via f8) but do not format just install
Jan 03, 2009 | Computers & Internet
AOpen ax4bs upgrade bios to up fsb?
Hi PapaFreeBird,
Go Lynryd Skynrd!
I'm only fairly knowledgable on this board, but I am virtually certain that you are chipset limited at the 100Mhz level. I don't think there is any way to work around it, short of upgrading the board.
I know this isn't what you hoped to gear, but I think you'll probably be pretty happy with the system anyway, at least until you save up for a new MB.
I hope this info is helpful. If you feel it is appropriate, I would appreciate a Fix Ya rating on this solution. Good luck!
Bob
Oct 29, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
It does'nt boot up
don't upgrade the bios unless it is necessary. as you have just installed that board... recheck all the connections to the board. when you say it doesn't boot up... do you mean the computer doesn't power up or it does not get past the boot screen... if it does get to the boot screen what error do you get after that ?
Robert
Sep 04, 2008 | Iwill XP333-R Motherboard
Upgrade from Pentium 3 to Pentium 4
what socket is the Pentium 3? Socket A. The sockets have to be compatible for example you can't upgrade a Dual Core for a Core 2 Duo because although the chipsets look the same the motherboard may not support the new instruction set. I had this problem recently as i wanted to upgrade my Intel Celeron D 3.02ghz to the Pentium Dual Core 1.8ghz and although the chips were identical and fitted perfectly in my mobo, the actual mobo i was using (foxconn) wouldnt work with it forcing me to buy an ASRock mobo and replace the entire system.
May 27, 2008 | Dell 2.8 GHz Second Processor for...
No singal after upgrade my cpu.
good pm...
have you checked your video (built-in or card) or your monitor sir?...does your mobo sir supports 2800 processors?i guess your mobo failed after doing so (upgrading from 1900-2800)...try to check it sir...hope this will help...
Mar 07, 2008 | Matsonic MS8147C+ (N82E16813184008)...
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Apr 26, 2007 | Jetway 939GT4-SLI-G Motherboard
AOpen AK77-8XN Motherboard Logo
126 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
