My phone model nokia E63, it is automatic restart when i press any key in phone . what is the solution?
If the battery is OK then your problem comes from the damage of operating system (Firmware).So, to solve this the only thing you have to do is to flash the phone.You can contact mobile repairing shop or Click here1 if you want to do it by yourself.And for your flash file follow this All nokia bb5 flash file.Good luck
SOURCE: Lock Code problems with E63 after hard reset
give me your imei and i will send you unlock code
SOURCE: my nokia 6233 is dead!!!
i was instaling a themen to my nikia 6233, but it seam that memory was full. any way. the mobile was of and now its not starting any more ? only starts for few seconds and then off!!
how can i reset it ? any help ? pleas till me step by step ..i am a bit confused !!
thanks
SOURCE: mobile restarting automatically
If the sim is faulty, then it can cause this problem.
If the phone does the same with different SIM cards, then check the sim contacts in the phone slot, if you cannot find anything wrong, then it is an internal problem, probablu with the circuits connecting to sim card slot on the phone.
SOURCE: Nokia 5800 restarts automatically
try factory reset
go to menu>applications>file manager>backup>options>backup now
this step is intended for content backup, if you don't care to lose your personal info skip it
backup done?
1.first way to apply factory settings: go to menu>settings>phone>phone mgmt.>factory settings>yes
2.another way to apply factory settings:(three finger salute)
now switch off your 5800
while it's off press and hold these three buttons at the same time send(green button) + end(the red button) + camera button(found on the side)
while you're pressing these 3 buttons switch on your phone and hold on to the 3 keys until the hands video is infront of you
the phone then asks for date and so...
tell me if the problem persists and try to clarify it further ahead
i own a 5800 and may be i can be of help
SOURCE: Cant send sms from my Nokia E63
go to your message settings and check the message center number to see if it is correct.this can hinder your text messages from going.i hope this helps
