Question about Evesham Computers & Internet
It not letting me go on on line - Evesham Computers & Internet
Well, i don't really think thats a prob with your PC, it might be your ISP or somet imo..
Try checking with ur ISP and ur Connection in Control Panel
Posted on Nov 12, 2008
93 deville burns alot of fuel, like a gallon a mile; no leaks in fuel line. Any suggestions?
A ruptured diaphragm in the fuel pressure regulator will let extra gas enter the engine through the vacuum line to the regulator. Pull off the regulator vacuum line. Any evidence of gas? Let the engine idle a couple of minutes with the vacuum line off. If any gas starts coming out of the vacuum line nipple on the regulator, then that was the problem. Replace the fuel pressure regulator.
Jun 16, 2015 | 1993 Cadillac DeVille
1981 Honda cb 650 custom can't et the front brakes to bleed just did a fluid change and can't get the oil to fill the lines again
A trick I used, was before you put the line on the master cylinder, fill the resivour with fluid and place your thumb of the hose. As you squeeze the handle let pressure off of the hole with your thumb then seal the hole again when you let the lever back out. this will prime the system.
Attach the hose to the resivour.
Take a pair of channel locks and squeeze the hose off about 6in down from the res. Use the same system. Let pressure off when you squeeze the lever and seal when releasing the lever. This should pull fluid donw in to the lines and eventually down in to the caliper. Once fluid squirts from the caliper, you can just use the bleed screw to let the air out and seal the line between pumps to not let air back in. This system works well for me. Good luck!
Sep 01, 2012 | Cars & Trucks
Wont let me go on line there is a signal was playing black ops and it just went off line buy wont let me go back on line
Sounds like your internet service provider has cut you off, or the network got cut off temporarily. Contact them to resolute your issue.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
My hoover steam cleaner will not put down the soap solution? Any suggestions!
The line may be clogged.
If you look in the tank see anything blocking?
No? Okay moving on. You may need to remove a cover or covers.
Find the lower end of the line / tube.
Carefully remove the line.
Now with safety glasses on take a can of air, and blow the the line & sprayer out. Replace all parts you removed.
In the tub, shower or outside. Add vinegar & distilled water to tank let set for 1 hour then see if it will work. Let the water go down the drain or outside. If this don't work you may have a bad sprayer switch.
Please let us know.
May 18, 2010 | Hoover F5842-9RM Steam Vacuum
Water dispenser does not work due to line freeze. what is the solution?
Turn off the water to the ice maker and turn the temperature up in the room. Let it sit at room temperature for a few hours to let the heat warm up the line. Is it the line on the back of the unit or down in the basement?
Feb 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Replaced manual fuel pump blew all fuel line out
Do you have more than 4 gallons of gas in the tank? Some models won't **** to prime with less than that in the tank. This is mostly an issue when there is air in the lines. There is usually a screen filter on the pick up, but blowing that out should have taken care of it at least for a few days. Another possibility is a pinhole leak in the line between the tank and the pump. That lets the pump **** air, which will not let it **** gas. There could be a larger in-line filter between the tank and the carb filter. Let us know if you find out what it is.
Feb 04, 2010 | Jeep Grand Cherokee Cars & Trucks
Merlin Plus. Have two extra line buttons
do you have a manual? the programming code escapes me...you need to remove the lines on that phone. it wont let you program a button over a line button, so you must first remove the "Line appearances" then you should be able to.
Let me know if you need to code for the removal of line appearances....
May 18, 2009 | Avaya Merlin BIS 10 Corded Phone...
Where is the fuel pressure regulator on a 2003 oldsmobile alero?
There are 2 fuel lines connecting to the fuel injector rail. The larger line is the pressure line and the smaller line is the return line. The smaller line attaches to the fuel pressure regulator. You will notice that the regulator also has a vacuum line attached to it. If you are planning on changing it your self, let me know. There is a specific way to change it for safety reasons.
Let me know.
Regards,
Mar 10, 2009 | 2003 Oldsmobile Alero
Unable to pick up line while line is in use
No.
The feature that lets you conference in is Executive Busy Override. There's also an intercom feature that is EBO Deny.
How it's programmed depends on your phone system and not the phone, but it typically (824) involves a program 608 change and turning it on by the 7331# command at each phone.
Carl
Jan 05, 2009 | Panasonic KX-T7731 Corded Phone
18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Computers & Internet Logo
Top Evesham Computers & Internet Experts
Simon Clarke
Level 1 Expert
Lakshman P
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
