Question about Liebherr Refrigerators
My Leibherr fridge/freezer -- fridge section is filling up with water from the drain hole that is obviously clogged. I pulled the unit away from the wall and the hose is located behind the fins on the back...what is the easiest way to unclog this hose?
  • mulq Apr 16, 2009
    the drain hole plugs up and water goes into the veggie bin. This is due to about 1" thickness in ice - I used hot compresses to fix this issue
  • 1,462 Answers
Put something flexible down the drain hole from inside the fridge and this will clear the blockage
Posted on Nov 12, 2008
Water accumulating inside the fridge
hi kostas.
Condensation runs down the back of the fridge and collects in the gully sitting at the back of the fridge where the water is then channelled through the drain hole into a container which sits on the compressor, it's then evaporated away.
How to Stop Water Collecting in Your Fridge ' eSpares Water accumulating inside the fridge Google Search
Nov 07, 2017 | Refrigerators
My Whitlpool Gold fridge GDSSHG is leaking water inside when the ice maker fills. Seems to be running down the back behind the metal backing and into the Bottom of fridge. Freezes there and then when that...
2 possible issues: 1st and most likely, water valve got stuck in open position - you need to shut water at the back of Your fridge and get new water valve. 2nd seen only couple times: when ice maker stuck in position when its calling for water, so valve opened all the time. As I said water valve 90% of a chance is bad. Hope that helps.
Mar 28, 2015 | Refrigerators
My whirlpool side by side Why is my whirlpool side by side refrigerator model ED2PHEEMQ00 leaking water out the door or the freezer side.
90 percent sure drain is clogged. when unit defrosts , water from said melting ice is drained away via drain hole and tube to underneaththe fridge. locate drain hole in bottom rear of freezer and pour hot water with turkey baster into hole until it runs out freely
Aug 31, 2014 | Refrigerators
GE PSDS5YGXCFSS - Water keeps pooling in fresh food section
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
Nov 06, 2013 | General Refrigerators
HMG1947 with ice maker. Intermittent problem getting worse! I am getting water on the inside bottom, which will leak out onto the kitchen floor if I don't catch it with paper towels under the bottom...
Is the freezer section cooling properly. If yes, then problem is drain hole blocked in freezer section.There is a water drain hole, which runs to the drain line.But if the drain hole is got clogged by ice, then water will leak from other end and you get water in bottom drawer.-------- try manual defrost procedure.----------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check, do you notice the same problem, if yes then defrost assembly board is faulty.But in most cases defrost reset procedure helps.----------- Thanks.Helpmech.
Sep 16, 2011 | Admiral Refrigerators
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
Why do i keep getting a puddle of water in the bottom of my frige? The water must be coming from the top because each day, there is water on top of the food containers all the way down to the bottom.
Sounds like you have a defrost drain issue. Often times these get clogged, and the back flow water drips into the fridge, usually the culprit on a GE is a clogged drain diverter, located on the outside back of the unit. Remove the tube by bending and pulling away from the diverter while holding the diverter firmly in place. Then turn the diverter one quater turn clockwise and it should pull down and away from the appliance. Clean this diverter out thoroughly, as it is likely full of gunk. However, on some older model GE top mounts, ive seen the drain pan underneath the evaporator coil inside the freezer with a small rust hole, and the water drips through this hole instead of the intended drain hole, the water then misses the tubing, and drips into the fridge. this drain pan will then have to be replaced.
Dec 10, 2010 | GE Refrigerators
Water is leaking into my fridge from defrost.
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system.
If in case the water is leaking on the floor then:--
There are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Unplug the unit from main power outlet and empty whole unit and keep both the doors open and then connect the power after 24 hours and recheck.This procedure is called manual defrost reset.If this helps then its OK,but if this procedure not helping then its the faulty defrost unit and it needs to be replaced.
You can get required parts from
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | GE Refrigerators
There is a small leak coming from a screw hole by the light in the refrigerator what could it be from water keeps dripping out
The drain inside the freezer is clogged. Your freezer goes into defrost every 8 to 10 hours. When it melts the ice built up on the coils, the water drains out of the freezer from a drain at the back down to a pan located under the fridge. You will need to remove the inside back panel of your freezer. Look at the bottom in the very back. There you will find a slopping place with a hole in the middle.This is the drain. There is something clogging that hole. I have found peas stopping them up. Take a turkey baster and fill with water. Push water into the drain hole then look for anything else that might clog the hole. Put unit back together. Problem solved.
Please rate solution
Sep 07, 2009 | GE Refrigerators
Water under veg bins
Hi. thanks for the question . the problem you have is with the drain tube, from under the freezer wall ,in the fridge. that tube is clogged up . pull fridge away from wall. locate the drain hose at the drain tray. clean. also clean all coils behind fridge thanks the appliance doc
Sep 30, 2008 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
653 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
